Old 07-03-2012, 10:35 PM   #1
1955 mancave
1955 mancave's Avatar
overdrive trans
so in my 1ton with a 454 i want overdrive so 700 R4 , gearvendor, modified Volvo OD unit or ?? please help
thanks as always
Henry.
1955 mancave is offline   Reply With Quote
Old 07-03-2012, 10:40 PM   #2
NCD1966
NCD1966's Avatar
Re: overdrive trans
I wouldnt use a 700R4 I have broken a few of those.. i say the best setup up for a big block is a th400 with a gear vendor unit
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 07-04-2012, 09:42 AM   #3
summerj
Re: overdrive trans
I don't know much about non GM transmission but I do know about the 700. The 700 R4 can be built solid to handle that 454. 1rst gear in a 700 is lower than both the 350 and 400. Make sure that you find a 30 spline not the 28 spline 700 used in most 6 cyl. models. Look for a late 80's early 90's. If you have a Dayco transmission parts shop near buy get the ceramic disk upgrade with master overhaul kit and have a recommended bench tech install it. You will also need to buy the 4th gear electric lock up conversion getI think summit has it? The stock disk packs in the 700 and a lot of other stock transmissions use a minimal amount of disks for each gear+ the stock disks are coated with a paper/cork material- This is what fails in these transmissions and this is why the 700 gets a bad wrap. When you upgrade to the ceramic disks you get a better grip - and more disks working together for each gear.. You can build a stock 700R4 to handle 1000+ HP.
That's a monster truck what will you be towing?
summerj is offline   Reply With Quote
Old 07-04-2012, 09:50 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: overdrive trans
thanks as always
Henry.
It will probably be more economical to find a 4L80E. This is the route I generally go. Remember, before the Allison 1000, the big block trucks came with the 4L80Es.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-04-2012, 09:56 AM   #5
'63GENIII
'63GENIII's Avatar
Re: overdrive trans
I think by the time that you spend the money to get a 700 to survive behind a big block in a 1 ton, you could have easily had a used (or possibly rebuilt) 4l80e with the stand alone controller. Now if you're using the truck like a 1/2 ton, that may be a diffferent story. I use my 1/2 ton like a 1 ton and I'm looking 4l80 or nv4500 (manual).
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-04-2012, 10:33 AM   #6
1955 mancave
Re: overdrive trans
what $$ would it take (est.) to use a 4L80E in PHX i can get a tow rated 700 for about $700.00
Old 07-04-2012, 12:05 PM   #7
vin63
vin63's Avatar
Re: overdrive trans
I can usually find used 4L80Es for around $500-$800. I use the Baumann Optishift TCU for around $500. I've never been able to make a 700R4 live behind my Pontiacs, and my racing transmission builder, Mike Stewart of Mike's Transmission - http://mikestransmission.com/, will not build one for my hot rods because they will not last with the torque I make...but, he has built me TH400s that handle my 1500+ ft-lb blown Pontiacs. The 4L80E is basically a TH400 with OD...keep in mind, it's not the horsepower that kills the trans, it'll be the torque.
