07-04-2012, 07:25 PM | #1 |
RAT1968 '68 Cab/'71 Parts
Checking My Gear Ratio..What Am I Doing Wrong?
One full revolution of the rear wheel (in neutral): One and a half full revs of the drive shaft.
Hummmm? Blocked the passenger's side rear wheel from rotation. Same count. I was on the wheel checking the wheel's t.d.c. on each attempt, and a partner was under the truck counting the d.s. revs. Same result on all tries. Am I dumb? Can't he count? Am I working on a Corvair Monza?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
07-04-2012, 07:33 PM | #2 |
Restoration Virgin!
Re: Checking My Gear Ratio..What Am I Doing Wrong?
try 2 rotations sounds like a 3.07 gear
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-05-2012, 07:17 PM | #3 |
When you have an open diff and rotate just one tire, the spider and side gears reduce the number of driveshaft revolutions by half, so you must do two rotations in this scenario as mentioned above. With a limited slip and both off the ground, only need one rotation to get it.
07-09-2012, 11:44 PM | #4 |
I've got grease on my mind.
Rotate the Driveshaft 2 times and count the wheel revs then divide by two
07-10-2012, 01:07 AM | #5 |
You have to rotate the tire twice., if you are getting 1 1 /2 driveshaft turns at 1 tire turn, then you more than likely have 3.07. If you were to rotate twice you will get a tad over 3 rotations.
These are guestimates , for a chevy rear end when you turn the wheel twice, non posi. I think if you have a posi you only have to rotate once. a tad over 4 driveshaft rotations +/- = 4.11 3 3/4 driveshaft rotations +/- = 3.73 3 1/2 driveshaft rotations +/- = 3.43 ? 3 driveshaft rotations =/- = 3.07. Last edited by Frijolito1988; 07-10-2012 at 01:13 AM. |
07-10-2012, 01:12 AM | #6 |
Since I rotated the wheel once and got 1.5 revs of the driveshaft, I have to figure 2 rotations of the wheel would give me 3 rotations of the driveshaft.
So, my fundamental brain says. 3.0:1.0. Which, giving a margin for error based on eyeballing, seems to easily translate to 3.07. Does that make sense? l l l l AHHHH, YES!!!! Thanks, All. V V V V
07-10-2012, 01:27 AM | #7 |
yep, you got it!
