Old 07-04-2012, 08:10 PM   #1
KrazyRay
KrazyRay's Avatar
Overload Setup Rear Leafs
This is a stock overload pulled from a 70 C/20 Longhorn. The only thing missing is the u bolts. Also included is the stock rubber stoppers. $25 plus shipping.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 07-04-2012, 08:31 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Overload Setup Rear Leafs
Ray - Interested...do you know if stock U-bolts will work w this set up? Would be nice in my K20. Pete
Old 07-04-2012, 08:39 PM   #3
KrazyRay
KrazyRay's Avatar
Pete, You will need the stock type u bolt, but longer because of the spacer.
Thanks,
Ray
Old 07-04-2012, 08:47 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
How much shipped to 87110?
Old 07-04-2012, 09:43 PM   #5
KrazyRay
KrazyRay's Avatar
Pete, I will get a quote tomorrow.
Thanks,
Ray
Old 07-06-2012, 02:07 AM   #6
KrazyRay
KrazyRay's Avatar
Pete, Sorry...Called in for work. Quote Fri.
Thanks,
Ray
Old 07-06-2012, 12:17 PM   #7
KrazyRay
KrazyRay's Avatar
Pete, Its $35 total to ship springs and hood latch. The leafs will go fedex and the latch and brackets will be stuffed in a large flat rate. Grand total is $65 shipped for everything.
Thanks,
Ray
Old 07-06-2012, 12:53 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks,
Ray
Ray thanks. Pack it up - I'll take the parts as long as the springs are correct for a leaf spring truck (going in my K20). Any chance you have pics of the helper springs installed? Couldn't find any posts on this in a non-coil truck. Send PM with PP address when poss. Will square up later from secure connection at home.
Old 07-08-2012, 11:44 PM   #9
KrazyRay
KrazyRay's Avatar
Pete, Here's a couple pics. Hard to get with the duallys. You set the spacer on top of your springs and then set the overload leaf. u bolt everything together. Use grade 8 bolts to attach the frame brackets.
