07-06-2012, 11:19 PM | #1 |
Firewall mount power brakes on a 52 chev!
Anyone used firewall mount power brake setup.I am wondering if I should go this way or not.
07-07-2012, 12:18 AM | #2 |
Re: Firewall mount power brakes on a 52 chev!
I will be using a firewall mounted power brake set up on my 51. I welded bracing across the inner firewall reinforcements. The brake pedal mounting bolts thru the firewall at the master cylinder and to the bottom of the dash where the steering column bolts in. I reinforced the dash mounting to handle the extra load and pressure the assembly will put on everything. See my build thread for pictures (starting at around #116). I don't have the master cylinder/brake booster yet but I'm confident it will work well.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
07-07-2012, 01:03 AM | #3 |
Moderator
There are some pics of one in my build thread also (see link in sig). I grafted it into the firewall then reinforced the inside with about 18" of 1.5x1.5 angle. Nice and solid.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
07-07-2012, 09:36 AM | #4 |
I am planning to use a firewall mounted hydro-boost on my 52' GMC
07-07-2012, 11:23 AM | #5 |
Thanks for your replies guys!I am just collecting as many parts as I can before I tear the truck apart.I still have to finish the inside of my garage also.
07-07-2012, 01:47 PM | #6 |
As Atomik said in his post it is necessary to reinforce the firewall so that it doesn't flex and crack. At that is why he said he put the reinforcement bars in it.
They work good and I had one in the 48 at one time but they are as ugly as home made mucky and the get in the way. The main thing I didn't like about it was that I had this big old glob of metal hanging right over my brand new shiny left valve cover and getting in the way every time I wanted to check the oil or do anything on that side of the engine. If you are prone to opening you hood at shows the first thing everyone sees is that booster and master cylinder. If you are ok with that, head on. |
07-08-2012, 06:21 AM | #7 | |
07-08-2012, 10:19 AM | #8 | |
If it dont flex I wouldend worry about it. but I would have sombody push and watch from the outside Just to be sure. Last edited by mknittle; 07-08-2012 at 10:25 AM. |
08-13-2012, 11:18 PM | #9 |
I'm interested to see if anyone has pics of this done on their truck? I have a camaro brake booster that I'd like to use for our '55, just need info on where to mount it.
