Old 07-07-2012, 07:50 AM   #1
kgmunro
65 lower ball joints
are the lower ball joints on a 65 c10 2wd just press in? Can they be done on the truck? What is the easiest way??
kgmunro is offline   Reply With Quote
Old 07-07-2012, 11:29 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 65 lower ball joints
Yep, they are pressed in. You can do it on the truck but you need a ball joint press. Most larger auto parts stores (at least in the US) can do a "loaner" tool or you can buy one.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-07-2012, 12:41 PM   #3
billd5string
billd5string's Avatar
Is that true of the C20's as well? I need to do the ball joints on my 65 as well.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 07-07-2012, 01:24 PM   #4
b2948kevin
b2948kevin's Avatar
Not sure about the C20, but I just did the joints on my 66 C10. I posted some details in my build thread. You can look on my signature.
On the C10, they are press in, and they are a pain to get back in if you dont use a quality tool.
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 07-07-2012, 09:09 PM   #5
chevy_mike
chevy_mike's Avatar
Yes, C20's are the same. They just use a larger ball joint but the process is identical.
Upper arm ball joints, if still factory, are riveted in, so you have to cut/grind the heads off and use bolts that come with the new ball joints.
Old 07-08-2012, 06:18 AM   #6
kgmunro
Thanks for the info I will be trying this today!!
