Closed Thread
Old 07-07-2012, 04:30 PM   #4326
OJ1988
Just a car guy
OJ1988's Avatar
Re: What did you do to your truck today!
Started my new engine for the first time today!
Got a squeling belt, not sure if it's actually the alt or the water pump. It's lined up real good, but squels real bad and alt pulley gets very hot!
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline
Old 07-07-2012, 05:29 PM   #4327
Clrussell
Clrussell's Avatar
Moved it from one side of the yard to the other so I could run the sprinkler, then thought real hard about installing my new headers.. But I already know they aren't going to fit so the question I'm asking my self is send em back and try to find the near impossible to find headers, or modify my clutch linkage to use the more common headers
61 apache
Clrussell is offline
Old 07-07-2012, 05:39 PM   #4328
67cheby
67cheby
67cheby's Avatar
just modify the linkeage
67cheby is offline
Old 07-07-2012, 06:29 PM   #4329
mud.man.rj
mud.man.rj's Avatar
Modify both headers and clutck linkage if you have too, then make it come to life.
mud.man.rj is offline
Old 07-07-2012, 09:54 PM   #4330
ItsRandy
ItsRandy's Avatar
Got the windshield installed, SafeLite...$95. Cleaned and painted the bed cross-sills.
ItsRandy is offline
Old 07-07-2012, 10:02 PM   #4331
stoutguinness
stoutguinness's Avatar
Got my truck on the road. But it doesn't sound right so I might have to do park it again haha. Seems like the carb needs tuning and possibly fuel supply problems. And after a complete bleeding of the brakes, they still go from stiff to soft and back to stiff. Maybe a leak?
stoutguinness is offline
Old 07-07-2012, 10:27 PM   #4332
67cheby
67cheby
67cheby's Avatar
Looks great ! And how did you get such a good deal ?
67cheby is offline
Old 07-07-2012, 11:44 PM   #4333
Clrussell
Clrussell's Avatar
Any tips on modifying the linkage? I have the clutch ball that's mounted on the engine block now (between #5-#7 exhaust port) and that's right where the header tube is.. The headers I have on it now are leaking bad and are going to get replaced.. I might tear the old ones off tomorrow and take the linkage off to see what I've gotta do to make it all work.. Fabrication on linkage should be manageable
61 apache
Old 07-08-2012, 12:34 PM   #4334
ItsRandy
ItsRandy's Avatar
It's not what you know it's who you know and they came to my house and installed the glass. I already had the windshield gasket, which fit perfectly (thank you Brother's Truck Parts). I was originally quoted $128, I was surprised when the tech said $95, I am sure it was because I had the gasket or the tech was trying to pick me up.
ItsRandy is offline
Old 07-08-2012, 12:37 PM   #4335
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
So...It's not who you *know*. It's who........
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-08-2012, 10:14 PM   #4336
Clrussell
Clrussell's Avatar
Got the passenger side header on, broke the battery feed off the starter in the process.. And I'm not real sure about the thermal coating on theese headers, it seems like it is already coming off just from me installing em.. I left it in the bag while putting it between the block and frame to keep from scratching it.. But it's like the coating is rubbing off.. Has anyone watching this thread done a hydraulic clutch set up on their 4 speed?? I've been considering it but don't know enough about it. I've searched a little on it but cant find somewhere someone has said get this pt# and this part # and put it together.. I just don't want to hav to piece it together 13 times to get everything right. I'll get a picture tomorrow of progress when it's light out..
61 apache
Old 07-08-2012, 10:21 PM   #4337
pat 70/71
pat 70/71's Avatar
Gave my 71shorty a bath and a trip around the block(no radio just motor)good times! Cheers, Pat
pat 70/71 is offline
Old 07-08-2012, 10:27 PM   #4338
jmdemon55
jmdemon55's Avatar
took the seats and gas tank out today. drained the tank and just as we expected it was nasty nasty nasty! found the fuel level sender stuck in place and missing the float as well. that might explain why the gauge didnt move!
will be ordering a new one tommorow.
jmdemon55 is offline
Old 07-08-2012, 11:16 PM   #4339
ScottG
Installed my Thorley headers and new exhaust. Had to notch the frame on the driver's side a bit. Looks and sounds awesome!!
'67 C20 LBW
ScottG is offline
Old 07-09-2012, 12:52 AM   #4340
ItsRandy
ItsRandy's Avatar
After going to the Brother's truck show I put the newly painted cross-sills back in the bed, swapped the rear springs trying to get rid of a bit of a lean, installed the rear shocks and got my exterior and interior mirrors put on. The right side mirror won't adjust so you can use it to see behind you (thank you Brother's Truck Parts).
ItsRandy is offline
Old 07-09-2012, 07:35 AM   #4341
oklalawnboy
oklalawnboy's Avatar
Belt could be a little loose but also the alt may be pulling real hard trying to charge the low battery. Tighten the belt a bit and charge the battery. My 2 cents worth.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline
Old 07-10-2012, 10:32 PM   #4342
magwakeenercew2jh
The punch list got a little shorter today:
Sun visors on, driver's bucket "electrified" (I'm going with the leather buckets) , slug for the rear view mirror glued to the glass,
steering wheel is on and horn 1/2 way "plumbed", took measurements for the seat bolt-down. New door handles are on.
If anyone knows what seat belts will work with these seats, that'd be a good tip for me. I bought these several years ago
and many brain cells ago...I am pretty sure the seats are GM. I found an inspection sticker under the driver's seat that says "2004".
Rear roll pan is welded in. And Butch, the body man par excellance is molding in the seams. Oh, Butch stopped the brake line leak
and is going to put a shifter shaft seal in the TH350 tomorrow....next leak to attack, bottom radiator hose .
One day closer....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-10-2012, 11:07 PM   #4343
72smoker
72smoker's Avatar
Got the wireing to the starter finished. Turned the motor over for the first time on it's own. A good feeling after a very long three year wate. Very close to the first fire of the motor.
72smoker is offline
Old 07-11-2012, 04:22 PM   #4344
Bert W
Bert W's Avatar
I painted my engine and broke down the front end, what a greasy mess.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline
Old 07-11-2012, 04:54 PM   #4345
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Wow ~
You alls are so busy ! .
I just installed my factory dual horns , good thing I bought a boxful at the junkyard as some were dead .
Interestingly , my '69 Stepper base model truck doesn't have the same dual horn captive nuts all the DeLuxe trucks I see , do .
It toots *much* nicer now .
I also added the last of the factory power brake to firewall support brackets I had in my box 'o parts .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-11-2012, 08:40 PM   #4346
mcmlxix
Collector of Projects
mcmlxix's Avatar
built some hood vents.... they'll get some screen underneath and powdercoat before being bolted to the hood...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 07-11-2012, 09:38 PM   #4347
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Bought HP Tuners VCM Suite Pro today...it can scan/edit my trucks tune and my TBSS...it'll be here tomorrow!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 07-12-2012, 12:43 AM   #4348
ItsRandy
ItsRandy's Avatar
My steering wheel and rear sway bar were waiting for me when I got home from work today. I started putin' the wheel on at about 6:30 and had the sway bar finished by 8:30. The sway bar went on great, I bought a Hotchkis blade type bar, really an easy installation. The wheel went on real easy too (after a little soldiering). I wanted a plain horn button but this what they (Summit) could supply.
ItsRandy is offline
Old 07-12-2012, 09:14 AM   #4349
dmw319
ItsRandy, nice! That is the steering wheel that I want to put on mine. Did you buy it at Summit or LMC? How hard was the install?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline
Old 07-12-2012, 05:22 PM   #4350
magwakeenercew2jh
Bad day today.
I had help, which was a GOOD thing. But when we filled up the coolant? At first, a happy day.
The reconfiguring and re-cinching of the lower radiator hose worked!!!! Then coolant started pouring all over the place.
Out of the freeze plug just under the motor mount on the driver's side.
Drats!!!!
Well, while that drained, we put in the TH350 shifter shaft seal with the special tool that came in the mail today.
Then, we were ready to put in the trans pan drain-plug. The guy that helped connect the tranny to the motor stripped the
new shiny aluminum pan plug threads. Never said a word.
So, instead of pulling the motor, we (I SHOULD SAY, "Butch"), removed the motor mount, the motor mount bracket, and then the rotten plug.
Napa Auto Parts had the ticket...a 1-5/8" rubber and steel dry-install plug for the block, and a one-oversize tranny drain bolt/plug.
$9.50 for the freeze plug and drain plug, $40 for 2 more gallons of Prestone and some extra little stuff, another hour of Butch's time.
Next saga tomorrow. Maybe fire it up if the fresh oil we'll put in doesn't spew all over. And if the trans fluid stays in.
And if the coolant doesn't find another hole. And if........
Lessons?
Note One to self: "When sealing up the motor on the stand, replace all the freeze plugs".
Note Two to self: "When installing a trans pan plug, don't have someone tighten it that won't
be around when the trans gets filled...Do it myself".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Closed Thread
