backspacing ???'s
how much backspacing can I go before hitting the frame????
I had a 15x14 custom steelies w/31x18.5 MT's under my 67short fleet. The only frame mod was removal of the factory bumpstop & bracket on the outside of the frame. It might actually clear; the main reason I removed it was for clearance when it was lowered.
have any pics??????
lots of threads
There have been lots of threads on this, try running a search on backspace. Stock is 4-1/2".
Silence is golden, duct tape is silver. - Scott |
The only pics I have are from years ago & My scanner doesn't want to scan them for some reason. It looked like a typical pro-street truck, the main difference was I used offset wheels instead of narrowing the rear-end. I didn't want to narrow the rear because I knew eventually I would step up to big diameter wheels.... which I did.
SCOTI how much offset did you use???????
Pretty sure the stock 15 inch steel rims are 3.5 offset. I've run 15 inch 4.5 offset rims with no problems.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
15x14 w/10" b.spacing.
SCOTI
If I make the frame mod and put some bigger tubs in the bed of my fleet side I should be able to run a 31x18 tire with out rubbing the frame. I do not have to move the trailing arms are anything else is that right.
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 |
The trailing arms remain stock.... you just can't use lowering blocks w/this set-up. I widened my tubs to the frame rail. I also had to tweak the e-brake cables so they wouldn't contact the wheels but that was pretty easy.
