GMC 351 V6 "M" Engine Parts
Does anybody where to get parts for these engines? I need a oil pan for 351 V6 M. Do they have the same bolt pattern as the chevy 305/350 v8 oil pan?
1990 Chevy C2500 4x2 350TBI 1997 Chevy K1500 4x4 350Vortec |
I am a Referee of life.
Re: GMC 351 V6 "M" Engine Parts
You might ask member coyoterun.He is a lover of the V12 version of these engines whhich are just a doubled one.He may have a source he would share.Or maybe a crossover parts reference.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Couldnt find that member.
The only oil pan that will fit is one from another GMC,v/6 engine.
Mike. ![]() ![]() |
Who sells them new or used?
![]() Join Date: Feb 2011
Craigslist, Ebay, Partsboard here...are sources
MusicMan70 1961 GMC Suburban |
Craigslist and ebay dont anything for GMC V6.
#8 | ||
"I ain't nobody, dork."
No oil pan... but there's quite a few parts for 305 and 351 V-6's on ebay...
http://www.ebay.com/sch/i.html?_trks...51+V6&_sacat=0 Froma little digging I did on Google... it sounds like a pan for a 305 V-6 might fit. Gary
Some parts are available for these engines new but very few, we recently sourced a fuel pump for one at the local parts distributor(star auto parts) but stuff like oil pan will have to be sourced used, have to hunt around.
The V6 has a skirted block like the Ford FE. It has no dent where it goes over the crank.
I received this info below about the oil pans, from one of the very knowledgeable Guys; Lewis Matkin, from the 6066 GMC website. Parts CAN be found on Craigslist; not always in your region or by direct order, but I have purchased many parts from the CL including my 401M.
http://www.adhuntr.com/ used to be Allofcraigs http://www.mecanicapedrosa.com/ all GMC V6 engines carry the same pan configuration. The only difference is the depth of the pan. The 305 pickup engine has a shallow oil pan and may not allow the oil-driven govenor spinner asm to be installed on the pump. It is a 5-qt. pan. However, if he finds one from a 305-351-401-379-432-478 out of a 4000 series or larger truck it should work. Most of these pans are at least 8-qt. capacity and will bolt up to any of these engines Best of luck with your search, I'll keep my eye out as well.
I also need pistons and connecting rods now too. Found broken pieces of a connecting rod and piece of the piston skirt. Thanks to all the replies.
![]() Join Date: May 2007
351M do show up on CL for sale , it sounds like it would be cheaper to find a used engine.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#14 | |
#15 |
Can I use 305c, 351c, etc connecting rods in M series engine block. I have a 351 V6 M according to ID tag on the truck. Ill check the castings on the block this week.
#16 |
Does anybody if the medium duty and pickup truck 351 used the same internal parts such as pistons, connecting rods, etc?
#17 |
Try cayoterun .I knew his nic was spelled funny but r when I posted before.I'm sure he's found a few things for them over the years since he's found enough to run a v12.
#18 |
A lot of the parts are the same. If you have a 351M, it came from a medium duty truck, 351E's were installed in light trucks 66-69. The "M" and "E" engines use a different intake and heads with bigger ports for increased air flow, the 351C uses smaller ports like the 305E. "C" and "M" engines (medium duty) use pistons with 4 rings instead of 3. There are plenty of parts for these engines around, it's just a matter of finding them.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
#19 |
Here is a truck in Phoenix getting parted that has a 305 v6.
http://phoenix.craigslist.org/nph/pts/3417200421.html
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
#20 | |
#21 | |
First join Jolly's 6066 Yahoo group it is dedicated to the V-6 in all its forms. Next when searching ebay punch in this search string 196* GMC anything listed for 1960-1969 GMC should pop up. The * serves as a wild card feature and will encompass and include all year items. There is a misconception that the V-12 was just 2 v-6 welded together, nit true. Here is a link to the national club, read to your hearts content. http://6066gmcguy.org/ Page on the V-12 engines http://6066gmcguy.org/TwinSix.htm Hopes this helps.
http://s1299.photobucket.com/user/jb...23904108567829 |
#22 | |
#23 |
I do not know if this will help, but I just got a box of mail in. In the box I had a stack of Car Craft mag,s in the December issue there is a write up about the v12. Here is the web site maybe this guy can help find the parts you need.
ThunderV12.com
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
#24 |
Thanks But looks like all he has is V12 parts.
#25 |
![]() Join Date: Mar 2002
If I was you I would look for a used engine. The parts off a common 305 V6 will work on your 351. Used engines go for $50 on up to $250. They are easy to find, once you start looking. I designed the HEI upgrade on Jolley's page and would highly recommend it.
ERL
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX Last edited by ETsC10; 11-21-2012 at 07:54 PM. |
