07-12-2012, 12:34 AM | #1 |
Axle Ratio Help
Okay my question is what is the gear ratio 3.08 used for and what to expect from it? I'm new to gearing info but learn quit. Thanks.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
07-12-2012, 02:01 AM | #2 |
Re: Axle Ratio Help
All I know is a 3.08 was popular with the 6.2 and 700r4 combo.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-12-2012, 07:35 AM | #3 |
Re: Axle Ratio Help
Lower numerical ratios (2.xx and 3.08) are supposed to be better for fuel economy, all else being equal. (ie, assuming the engine power band is unaffected, etc).
Higher numerical ratios (4.xx and 5.xx, etc) are better for low end launch, as they provide more torque multiplication. They are also worse for fuel economy simply because the engine has to spin faster and more times when going down the road. As a lay person, I like to start with 3.42:1, and then move from there (ie, lower ratios for better fuel economy - or Pontiacs; higher ratios for more launch or racing applications). If you are asking about availability in Chevy trucks specifically, they are usually found in those models more designed as daily drivers or light duty work trucks where you want to try to eek some fuel economy out of them. Powertrain charts (like the one shown in this link http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf (page 13) ) are used to track the usages. In this case the base RPO GQ1 is 2.73:1; Optional GU4 is 3.08. Does that answer your question? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-12-2012 at 07:44 AM. |
07-12-2012, 10:11 AM | #4 | |
Re: Axle Ratio Help
07-12-2012, 02:07 PM | #5 |
Parts and more parts
Re: Axle Ratio Help
You have to think about what kind of driving that you will be doing. Also what type of transmission are you running and where do you want your RPMs at on the engine for aligning with the power band of that engine. Also consider your tire diameter in this evolution. If you get the combination to the point that you are running at 1600 RPMs on the highway, then if there are no hills, you should have no probelms. However if you have any kind of hills or even a lot of intersections that you have to accelerate from, then you will be in trouble with your fuel economy. The engine will have to work harder to get up to speed and then stay there.
My son's truck ended up with a 700 R4 and a 3.08 gear ratio and his fuel mileage went into the dump, at approximately 10 MPG. We put a 3.73 gear ratio behind the 700 R4 and he now gets around 14 MPG. The engine runs better and will be in the power band when needed and does not have to overcome the drag of being geared wrong. I use a set of formulas to calculate what I want to achieve and that lets me get my gearing/tranny outpu and tire sizes where I want them for performance. RPM =GEAR RATIO x MPH x TRANS OUTPUT RATIO x 336 TIRE DIAMETER MPH = RPM x TIRE DIAMETER REAR AXLE RATIO x TRANS OUTPUT RATIO x 336
Frank |
07-12-2012, 02:18 PM | #6 | |
Re: Axle Ratio Help
07-12-2012, 03:05 PM | #7 |
Re: Axle Ratio Help
What that setup (oversize tires and overdrive), you'll be lugging that 305 with 3.08's. For best fuel economy, you want to select a gear ratio that'll keep your rpm's at around 2000 at cruising speed with tires you intend to use.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
07-12-2012, 03:06 PM | #8 |
Re: Axle Ratio Help
What that setup (oversize tires and overdrive), you'll be lugging that 305 with 3.08's. If fuel economy is what you're after, you want to select a gear ratio that'll keep your rpm's at around 2000 at cruising speed with the tires you intend to use.
07-12-2012, 03:08 PM | #9 |
Re: Axle Ratio Help
Okay what do you suggest is the best gearing to use? Just so everyone knows this is the setup that came factory on this truck except it had 31" tires.
07-12-2012, 03:28 PM | #10 | |
Re: Axle Ratio Help
However, if you're just going to use the truck for solo driving and want the best fuel economy at 55-60 mph, your best bet would probably be 3.73's. Here's the numbers for 3.73's. Speed = 60 mph Tire Diameter = 32" RPM's = 1645 If fuel economy is what you're looking for and you carry no heavy loads, I would suggest going to P235/75/15's tires. You'll gain a 1-2 mpg with just this. Speed = 60 mph Tire Diameter = 28.9 RPM's = 1821 This would be you put you into a more efficient RPM band and the tires would produce less wind drag and less rotational mass (which kills fuel economy). Also, keep your speed down. Any faster than 60 mph and fuel economy plunges with these vehicles and even more so with a 4x4.
07-12-2012, 03:34 PM | #11 | |
Re: Axle Ratio Help
07-12-2012, 03:52 PM | #12 |
Re: Axle Ratio Help
What axle ratio is in the truck right now?
07-12-2012, 03:59 PM | #13 |
Re: Axle Ratio Help
3.08 that's why I was wondering, about how I want to go with this truck.
07-12-2012, 06:00 PM | #14 |
Re: Axle Ratio Help
That's an insane axle ratio behind a 305. At 60 mph with that setup in O/D, the engine would only turn over at 1358 rpm's. That's way too low rpm's for that engine at that speed. Does the engine even have enough power to use 4th gear? However in 3rd gear (direct drive) the rpm's would be 1940 rpms which is perfect. I guess you could just cruise in 3rd gear and not worry about changing axles.
07-12-2012, 07:07 PM | #15 | |
Re: Axle Ratio Help
07-12-2012, 07:47 PM | #16 | |
Re: Axle Ratio Help
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 07-12-2012 at 07:52 PM. |
07-12-2012, 07:52 PM | #17 |
Re: Axle Ratio Help
But isn't a 700r4 an overdrive transmission or am I wrong?
07-12-2012, 07:53 PM | #18 |
Re: Axle Ratio Help
07-12-2012, 08:01 PM | #19 |
Re: Axle Ratio Help
So what is my best option for my driving needs?
07-12-2012, 09:43 PM | #20 |
Re: Axle Ratio Help
Please define your driving needs.
How much are you willing to spend? How much weight are you planning to tow? How many miles are you planning to drive it? Mainly City or Highway driving? Do you want it performance oriented or fuel economy oriented?
07-12-2012, 09:49 PM | #21 |
Re: Axle Ratio Help
Willing to spend whatever I might have to, weight wise is various things but if it is something too heavy I will use my dads truck. But overall nothing too heavy, like cleaning out houses and that type of stuff. Miles is another thing I can't really determine or it be definite. Mainly though it will be driven in city. I would like power but would rather have fuel economy. Hope this helps.
07-12-2012, 09:58 PM | #22 |
Re: Axle Ratio Help
A set of 3.73's would give you a little better fuel economy around town and you'll actually be able to use O/D when cruising.
Or you could rip out that 305 and put in a 6.2L diesel and keep the 3.08's. It would get significantly better fuel economy around town. Or if money is no issue, you could put in a Cummins 6BT and enjoy both power and good fuel economy.
07-12-2012, 10:08 PM | #23 | |
Re: Axle Ratio Help
07-12-2012, 10:12 PM | #24 |
Re: Axle Ratio Help
i have 3.42 in my c 20 with a sm 465 and a 350. i find it a good all around gear. i dont remember what size my tires are 265 85 16?? stock size i think. i get good milage 21 mpg at 70 14.5 in the city where i live. can still pull any trailer that i should have to. i have driven these trucks with the 3.08 and i think they suck ass. the 4.10 that is in my diesel good for city and pulling crap for the highway. just my .02
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
07-12-2012, 10:29 PM | #25 |
Re: Axle Ratio Help
Here's my .02
My 86 C10 (HD half ton 6100 GVW) has been a work truck all it's life with a 305, SM465 & 3.08 rear axle. It's handled everything you could throw at it- city, highway, heavy loads, light loads and towing- while providing 15mpg. (Top speed is about 65mph) I would leave it alone, unless it breaks. |
