Old 07-13-2012, 09:14 AM   #1
Shock_Me
Shock_Me's Avatar
Lock cylinder removal (without key)??
Hey all,
Is there a way to remove the lock cylinder in the ignition without the key? I know how to remove it with the key, but do I need a locksmith to do it without the key?
Shock_Me is offline   Reply With Quote
Old 07-13-2012, 09:37 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Lock cylinder removal (without key)??
Take a sawzall from behind and cut it off.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-13-2012, 09:51 AM   #3
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
1/4" drillbit into the lock from the front - its worked for me a few times.
Todd Hepler is offline   Reply With Quote
Old 07-13-2012, 11:37 AM   #4
Bert W
Bert W's Avatar
I would have to agree with the other fellas. Get a new or used switch with a key and drill out the old one. I'd probably start with a 3/8 bit.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 07-13-2012, 12:04 PM   #5
Shock_Me
Shock_Me's Avatar
Thanks guys. I sent out the VIN to GM's vintage division. Might be able to get the key code from them, we'll see. If not we'll drill the lock and replace it with a new barrel.
Old 07-13-2012, 12:30 PM   #6
PHAT TONY
PHAT TONY's Avatar
My brother got one out of a '67 for me using a couple small pics and a straight pin; I couldn't have sat there that long!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 07-13-2012, 12:32 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Truck is too old to do that.
The first thing I would do is to pull the passengers door lock out and see if there is a code number stamped into it. If there is take it to a locksmith and have him cut you a key. If the locks are all original the key will fit the ignition. If you don't have a locksmith close PM me the code number and I will cut you a key and send it to you for 8 bucks. If there is no code number on it, the door lock can still be disassembled and de-coded to cut a key. The destructive methods would be a last resort for me.
Picture shows the location of the code number.
LockDoc
Leon
Old 07-13-2012, 12:35 PM   #8
kcsa75
kcsa75's Avatar
LockDoc knows all.....Leon is wise!
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-13-2012, 12:41 PM   #9
LockDoc
LockDoc's Avatar
He got really lucky then. The GM sidebar lock cylinders (used from 1935 to present) are almost impossible to pick, even by very experienced locksmiths. I have been a locksmith since 1977 specializing in automobiles and motorcycles and I can count on one hand the number of GM sidebar locks I have been able to pick, unless they are totally worn out....
LockDoc
Leon
Old 07-13-2012, 02:46 PM   #10
GRX
GRX's Avatar
Ditto on what LockDoc said. Did exactly that with a GTO which I bought several years back.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-13-2012, 05:09 PM   #11
72chevyk10
I built it
72chevyk10's Avatar
or to get the assembly out (of truck), i have had to pop the chrome cover off before. its just crimped on around the edge. thats all that holds the bezel to the key cylinder.. after that gets poped off its all easy to disasemble, cept the lock cylinder is still in it.. but easyer to work on
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 07-14-2012, 12:11 AM   #12
LockDoc
LockDoc's Avatar
I have done that too but it depends on the lock cylinder it has in it. For some reason the diameter of the face of the cylinder is larger on some of them and that doesn't work.
LockDoc
Leon
Old 07-14-2012, 10:45 AM   #13
late68
late68's Avatar
I have the same issue with my truck Lockdoc, but I don't have the door locks that came out of it. Is there a number on the ignition cylinder itself?
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 07-14-2012, 11:37 AM   #14
19stepSide72
wanna be 67
19stepSide72's Avatar
Even if the passenger side has no code. Take it to a locksmith. I just had this issue. I had four new keys made. $21. Great deal without stress or damage. That is if it is keyed alike.
19stepSide72 is offline   Reply With Quote
Old 07-14-2012, 10:13 PM   #15
LockDoc
LockDoc's Avatar
Yes, most of them have a code number on them. Problem is if you don't have a key it is almost impossible to get them out without destroying them.
LockDoc
Leon
Old 07-27-2012, 06:57 PM   #16
Torqueforce
I figured instead of starting a new thread I'd add post in this one. How do you remove the lock cylinder if you have the key? I just bought a new ignition and lock cylinder and put them together prematurely only to find out you have to put it in the dash and lock it down before you put the lock cylinder in.
Torqueforce is offline   Reply With Quote
Old 07-27-2012, 07:31 PM   #17
GRX
GRX's Avatar
Use a large paper clip. Follow LockDoc's advice in post #3 of this thread.
67-72chevytrucks.com/vboard/showthread.php?t=476080
Old 07-27-2012, 10:47 PM   #18
LockDoc
LockDoc's Avatar
See post #4 in this thread...
http://67-72chevytrucks.com/vboard/s....php?p=4533102.
The one above is actually how to install one...
LockDoc
Leon
