Old 07-14-2012, 10:11 AM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
home made wooden center consoles
hey guys, im debating on trying my hand at drawing out and making my own center console for my pickup to incorporate possibly a few gauges, a ratchet shifter and a couple cup holders. May add 6x9 speakers into the side of the console as well if i have room to do so. My questions are as follows.....
  • Whats the best type of wood to use for this, since it WILL be getting upholstered
  • Is there any certain type of wood to use if id like to try and incorporate some bends into the piece versus straight lines and angles
  • Does anyone have any tips on making a wooden center console so it looks like a professionally built or bought piece
  • Whats the best way to go about making cup holders, is there any type of a "liner" i can buy/make so their a fully enclosed piece or will it come down to just screwing say a 1x4 about 3" down from the hole for the bottom part of the cup holder
  • Whats anything think about possibly adding some LED lights inside the console so it glows from the inside out at night.
Like i said thats only a few questions to get me started, im not the best carpenter/wood worker but in my head im not thinking this will be too bad of a thing to create. All i need is 2 sides and a top, possibly some way of mounting to the floor (hate to screw it into the floor though) but im thinking itll take up the entire center trans hump of the truck so movement SHOULDNT be a prob. Depending on how wide its make or how many areas i can get away with correct looking flat spots i may add up to about 5 gauges in it. Im going to try and incorporate a B&M Pro Ratchet shifter INTO the top of the unit, rather than using the aluminum case that it comes with. Again, no idea how that shifter mounts to begin with, but id almost assume its a flat piece at the bottom and just a metal frame with linkage etc. Lots to try and figure out here
Also, if anyone has made their own wooden center console please post up pics so i have an idea what i can build and how itll look in the end.
Thanks Guys!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 07-14-2012, 11:37 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: home made wooden center consoles
I can at least toss up a picture of what the last 91 burb I stripped down had in it. No idea of the type of wood, I'm more of a metal man. I still have it here someplace if you want more photos of it.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-15-2012, 11:19 AM   #3
ProStreet83C10
Drag Racer
wow...i woulda figured id have more than one reply by now, i figured there'd be a lot of these made for trucks here etc.
Anyway, i got some measurements yesterday, got out some paper a pencil and a ruler drew out some designs id like to incorporate into the console and went shopping for a list of products needed. Now, console drawings do not have any measurements on them as i just wanted to get a design layed out on paper to see how itd all come together. Heres what i got so far.
Im no artist mby any means, so bear with the shotty drawings etc
Dimensions measured in truck
Initial drawings of floor itself with dimensions
Idea of wood dimensions needed for console
Drawn up idea of console id like to build - or something similar
Top view
Idea of shopping list with pricing of what i dlike to use
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-15-2012, 12:31 PM   #4
C-10 simplex
Well since it's been a day with not to much activity on this thread, i suppose i can jump in.
i tried making my own console a few weeks ago, but decided since it was only 2 gauges for right now, it would be more economical to just leave the gauges where there are for now----clamped to the ash tray door and glove box door. But i am definitely interested in re-visiting the idea.
i can't help with questions 1-4, except to say that i was using 1/2" plywood because it was what i had available in the garage---didn't want to spend any $$$.
As far as adding the led lights, yes! i intended to do that AND use them behind special labeling for each gauge which i'll get into more detail if the project ever moves foward again.
As far as securing it what i was planning on doing and maybe suggesting in general was to clamp it to the bottom of the dash. This way you don't have to drill into the floor.
But my question in general and to everyone is how to you get the contour of the console to match the contour of the floor and dash? i tried using poster board/cardboard as a mock-up first. Is this what you have to do?
C-10 simplex is offline   Reply With Quote
Old 07-15-2012, 01:19 PM   #5
ProStreet83C10
Drag Racer
i havent done anything as far as floor mock up yet, i actually dont intent to box the console in on the front or rear, as i plan to run it all the way back to the front edge of the seat and run it up under the dash to the heater control box. I guess building and fitting will decide that aspect of it, however, if i DO decide to fully box it (which may happen just for strength purposes) i will likely use cardboard or posterboard and transfer to wood.
Im still not 100% sure on the design as a lot could change but id like to be able to almost fully hide the shifter cover, or somehow make the shifter work without using the cover, however the design of the shifter appears that it needs the curve in the top to indicate the gears correctly. Now, that doesnt mean i cant take that top curve of the shifter box and transfer it to a piece of stainless steel or polished alum and match the curve and place into console, but then im pretty much doing same thing as if i were to just keep original cover on shifter, which is what will probably happen.
As far as LED lighting, im still kind of wanting to use it, but im not sure how exactly itll light anything up if i fully box in the console, the only thing i could do is maybe around the 6x9 speaker openings, drill a bunch of holes that resemble the chevy bowtie logo and have that glow through the box. what i DONT want to happen though, is to over do it and make things look tacky. im sure id get some glow around the shifter case where the hole would be cut and id also like to somehow get some glow around the cup holders, but again, being their a solid piece minus a drain hole in the bottom, im not sure how they would create any type of a glow.
I guess a lot of this will just have to come along as i build and see where things go. Again, if ANYONE has ideas for me or suggestions PLEASE fill me in with them, as im going off a VERY basic design right now and anything that would customize it more or make it more eye appealing would be GREATLY appreciated
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-15-2012, 01:57 PM   #6
ProStreet83C10
Drag Racer
oh and for reference, heres some pics of the cup holders im looking at as well as the shifter im planning to use
Shifter
Cup Holders
http://www.ebay.com/itm/STANDARD-STA...item5d33d8ed8e
or
http://www.ebay.com/itm/Aluminum-Cup...82dca0&vxp=mtr
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-15-2012, 03:46 PM   #7
primrrd
primrrd's Avatar
Looks like a good plan, so far.
If you plan to cover it with vinyl- mdf is low cost and very easy to shape (ie round corners, or smooth curves on several layers) and work with.
you could accent it with brushed aluminum panels, thin harwood plywood panels, etc. coating it with a layer of f/g resin and matt (like a lot of guys do with speaker boxes) will waterproof it and lend strength.
keep us posted!
primrrd is offline   Reply With Quote
Old 07-15-2012, 07:03 PM   #8
ProStreet83C10
Drag Racer
well i actually JUST bought (2) 2x4' pieces of 1/2" Oak plywood, which i picked out VERY nice grain patterns, what i may do before upholstering it is try staining it and just see how it comes out with a real nice oak stain.
Piece 1 - Front
Piece 1 - Back
Piece 2 - Front
Piece 2 - Back
Piece 2 is a lot harder piece to choose front from back as BOTH sides of piece 2 have a really nice grain pattern
Anyway, im going to try this glue as well, may also staple the piece together just for extra strength
I also walked around a bit and was looking at possible trim pieces to finish the edges with rather than just have a plain butted piece of wood. Heres a couple i found to look in to, their plain and simple yet might make a really nice accent esp. if i maybe try a 2 tone colored console
Unfinished Oak outside corner trim 3/4" x 3/4" x 8'
http://www.menards.com/main/home-dec...050-c-7621.htm
Unfinished Oak outside fluted corner 3/4" x 3/4" x 8'
http://www.menards.com/main/home-dec...052-c-7621.htm
with the fluted corner, id probably finely sand it to round, as the fluting is so minimal its not noticeable anyway, you can really only feel it with your fingers.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-15-2012, 08:57 PM   #9
C-10 simplex
Oh wow---i hope you're using 1/2" ply because you wanted to; i didn't say you HAD to---i only used it because i had it laying around.
On the other hand maybe 1/2" ply IS good to use?
P.S. i used a router and sabre saw to cut the pieces out. i recommend using a router---they are amazing.
Old 07-15-2012, 11:31 PM   #10
ProStreet83C10
Drag Racer
i intended to use 1/2" the entire time, 1/4" is too thin to safely nail or staple together without possibly splitting the wood and 3/4" is FAR to thick and heavy for a simple console in a vehicle. So realistically, about the only good thickness ply wood to use is 1/2 if you want strength and durability without a whole lot of weight.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-16-2012, 04:58 PM   #11
crazeetxn
crazeetxn's Avatar
    Looks like you already bought some so that's answered. Your 1/2" should work fine. You were right as 3/4 would be heavy and 1/4 wouldn't give you holding strength
    They make a bendable plywood, but if you want, just cut some kerfs in the back (almost all the way through). Space them out about 1/2" from each other. Whether it's a table saw or cicular saw, be careful. The cuts go across the sides and not the length. This will help bend it around corners and such. But you'll have to figure out someway to cover the cuts up as they'll be exposed on the finished piece.
    Google some pics and see what you can find.
    Look around the internet. There has to be something out there.
    I think it would look cool. Just wire it into your light switch so it comes on when you turn your lights on.
Thanks Guys!
See above!
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 07-16-2012, 07:31 PM   #12
ProStreet83C10
Drag Racer
What???
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-16-2012, 08:12 PM   #13
crazeetxn
crazeetxn's Avatar
I tried to answer your questions by italics in your post
1st - '68 long bed
2nd - '81 SWB
Old 07-16-2012, 08:30 PM   #14
jitteryguy
GoatLube Experss
jitteryguy's Avatar
heres what I did for mine, there front and rear console.
this is the rear.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 07-16-2012, 08:34 PM   #15
jitteryguy
GoatLube Experss
jitteryguy's Avatar
the front , I will upholster it tomarrow.
'85 1/2 ton CCSB
'92 S10 350/350
Old 07-16-2012, 11:04 PM   #16
ProStreet83C10
Drag Racer
looks awsome, def more skills than i have in making that.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 07-20-2012, 12:06 AM   #17
ProStreet83C10
Drag Racer
im hoping this weekend to possibly start cutting into this and see what happens
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-27-2012, 07:01 AM   #18
kikkegek
kikkegek's Avatar
nice thread, any progress? I want to build a custom one for my K20 Suburban and stiull have access to the 4WD stick
kikkegek is offline   Reply With Quote
Old 10-27-2012, 09:02 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
my 88 has two "jump" seats
it dosn't go up too far to the dash
turns into a seat when you flip up the cupholder
padded back and seat,flip the seat fwd and got storage
It's a bolted to the floor steel frame(bolt holes behind shifter)
gona reuse the frame enlarge the box (hummer stlye) mount to the 78 Jimmy
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-27-2012, 10:20 AM   #20
kikkegek
kikkegek's Avatar
thanks john. nice dog.
Old 10-27-2012, 09:56 PM   #21
redrat
gearhead
redrat's Avatar
What is in that green bag behind the dog?? Looks kinda like a body!
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 10-27-2012, 11:27 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
oh right!,I forgot sorry next time i'll crop that arm out
acually was to show the little matching cupholders over the wheels lol
i'll grab a shot of the seat in the AM it's out now
John
Old 10-28-2012, 08:43 AM   #23
oldmann1967
When you use the monkey glue, wet both sides of the joint with water first. You will get better penetration and get the curing process started. Polyurethane glue uses moisture to cure.
oldmann1967 is offline   Reply With Quote
Old 10-28-2012, 11:42 AM   #24
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is Swervin Ervins console, Hey Swerve you still out there
http://73-87.com/7387garage/interior/console.htm
Malo83 is offline   Reply With Quote
Old 11-02-2012, 09:34 AM   #25
motornut
78K & 79C Jimmys
motornut's Avatar
won't fit right now
and it's missing the seat pad
John
