Old 07-14-2012, 10:52 PM   #1
laynrockers
laynrockers's Avatar
Question Gas tank for gen4 motor & porterbuilt kit
Looking for gas tank i can mount between frame rails in the rear that will have all the necessary hook ups for a gen4 motor. Can you guys helps me with what specifically the tank needs besides and supply and return?
I have seen a few options one from performance online but it runs over $800. And delmo i heard runs an older style blazer tank but dont know if it will work for modern gen4 motor..
how do i go about a sending unit? and fuel pump?
All help is much appreciated.
Kris
laynrockers is offline   Reply With Quote
Old 07-14-2012, 11:01 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Gas tank for gen4 motor & porterbuilt kit
Check one of our sponsors....Boyds Welding. Sells them setup for a carb....or efi and they look good and are a great fit.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-15-2012, 12:00 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Dunno what Blazer tank Delmo uses, but if it'd the '73-'87 style, the '87s are made for EFI. Also, PB sells tanks as well...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-15-2012, 01:23 PM   #4
chevy72blu
chevy72blu's Avatar
I went with a Boyd's tank as well. They arent cheap, but keep in mind that it also comes with a premium intank efi fuel pump already installed. Its also nice to have something that really is purpose built and made in the USA by skilled craftsmen.
chevy72blu is offline   Reply With Quote
Old 07-15-2012, 02:40 PM   #5
laynrockers
[QUOTE=68GMCCustom;5486507]Check one of our sponsors....Boyds Welding. Sells them setup for a carb....or efi and they look good and are a great fit.
I will look into this. My first concern is how low it site below the rails. I will have to see if this tank is mounted above the rails what the measurements are. I dont have much room considering the truck will lay frame.
Old 07-15-2012, 05:42 PM   #6
68GMCCustom
I don't know your setup but if you have the room under the bed to mount the tanks tabs on top of the frame rails...I would think that what would be left hanging below would be within an acceptable range considering the rear of the frame kicks up several inches.
That said............Boyd's welding will build it to your specs. Also...if you're not in a hurry they have group buys twice a year I think.
Kurt -
