Old 07-15-2012, 05:59 PM   #1
fanmanj
fanmanj's Avatar
Beyond annoyed with my truck's A/C!
Ok, here's the deal. I tried to charge my A/C in my truck about 6 months ago, compressor worked great, quiet, pumped just fine. The freon leaked out in less than a day. So, I just made attempt #2... new accumulator, office tube, new o-rings, flushed the system and added 6 Oz. Of Ester oil. Vacuumed the system down, held 30 in for about 30 mins. Charged the system,around 40 psi low/225hi at idle. Perfect. Lasted 3 days.... Turns out my compressor housing is leaking! Son of a........ I am beyond ticked. Anyone know where I can get a good r4 for a decent price?
Jay Bernard, Thibodaux, LA
1986 SWB Sierra Classic
Stock roller 350/700R4
2008 Buick Enclave CXL
3.6 VVT, 6spd auto.
PAINFULLY stock... (wife's ride)
fanmanj is offline   Reply With Quote
Old 07-16-2012, 04:28 AM   #2
BamaDave
Re: Beyond annoyed with my truck's A/C!
can't help you with finding what you need sorry, but I sure would like to change mine to r4. I just charged mine and it leaked out in a day.
BamaDave is offline   Reply With Quote
Old 07-16-2012, 08:21 AM   #3
rs72z
rs72z's Avatar
Be sure and use a new compressor not a rebuilt. Your other option although pricey is to swap to a sanden compressor.
pm sent.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 07-16-2012, 08:55 PM   #4
DetroitIron
DetroitIron's Avatar
pm sent.
X2. I bought a new R4 from Advance Auto plus I replace every ac part and o ring in the stock system. Working awesome after after one week. 40 degrees out the center vent. I used PAG 150 oil and charged the low side to about 30 psi. All my research suggested new not reman compressor. Good luck
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 07-17-2012, 07:54 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I just fixed mine with a similiar problem. The pressure built up on mine and blew out the front seal. It was an old compressor sitting on the shelf for a few years. I finally installed it. My local shop replaced all the seals and checked compression for $97. If the compressor failed, they would take that price off a new compressor. Call your local rebuilding shop. Mine runs great!! Mine can blow 60 degrees on a 100+degree day!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
