Old 07-15-2012, 10:37 PM   #1
That Mud Truck
4wd conversion
How would i convert my 72 2wd shortbed into a 4wd?
That Mud Truck is offline   Reply With Quote
Old 07-17-2012, 06:43 PM   #2
cal30_sniper
cal30_sniper's Avatar
Re: 4wd conversion
Unless you are a very competent welder with a frame alignment shop, your only feasible option is a frame swap. It would probably be easier to just find a 4wd truck to begin with and start off with it. You'd need to find one anyways if you were going to do the swap, and it would save you a lot of work and time to just avoid the entire swapping phase and start working on a different truck.
-cal30sniper
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 07-18-2012, 11:22 PM   #3
That Mud Truck
Re: 4wd conversion
Ive been looking for a 4x4 but cant find any!
I have some danas in my backyard, and my cousin could probably get me a good deal on the tcase and trans, but what else would i need?
Old 07-18-2012, 11:44 PM   #4
cal30_sniper
Re: 4wd conversion
What else? To get them welded in straight. It's next to impossible. All of the steering gear and front suspension linkage is also completely different. Unless you are a very experienced fabricator and auto mechanic, with lots of specialty tools, you do not want to try and fab up your own four wheel drive.
Old 07-18-2012, 11:51 PM   #5
andrewmp6
Re: 4wd conversion
Do a search on here some have done a 4x4 swap before its a big job and you need a parts truck to pull it off right.
Old 07-19-2012, 09:46 AM   #6
That Mud Truck
Re: 4wd conversion
2 of my brotjer in laws are mechanics and im a pretty good welder.....
Old 07-19-2012, 02:44 PM   #7
69gmcc10
69gmcc10's Avatar
Re: 4wd conversion
It is popular for ifs 4x4 chevys to do a SAS (solid axle swap) from older trucks all the time. i dont see why you couldnt do a conversion from 2wd to 4wd if you measure 5 times and cut or weld once. I would do a google search for "Chevy sas kits" and see how they do it or if any of there kits would possibly work for you, also look at offroad unlimited they have some good parts and brackets you might use! You might also think about finding a 73-87 chassie and make body mounts for your truck to fit on it.
69gmcc10 is offline   Reply With Quote
Old 07-19-2012, 10:40 PM   #8
That Mud Truck
Re: 4wd conversion
Yea thats what i was thinking... Just put some danas and get different trans and tcase etc.... But from what others are saying its more than that.
Ive done SASs on other trucks but with rockwells but the trucks already had 4 wheel drive so i dont really know how to add it.
I found a couple of swap threads that im gonna look at thatll hopefully help me out
Old 07-20-2012, 02:07 AM   #9
jhaymon
jhaymon's Avatar
Re: 4wd conversion
you feel like making a drive to Beaumont. check southeasttexas.com
is it done yet?
jhaymon is offline   Reply With Quote
Old 07-20-2012, 07:53 AM   #10
That Mud Truck
Re: 4wd conversion
There were only 4 annd i wouldve only been inkterested in one but they wanted 16k... Thats way outta my price range
Old 07-20-2012, 09:51 AM   #11
obijuan
Re: 4wd conversion
It ain't bad. I'm gonna do my 67 next year. Find the 4x4 motor crossmember for your year/motor. Remove all the 2wd crap and have an empty engine bay and bare frame rails. Find spring center, set your desired wheelbase and put the front leaf hangers on the frame. Change your steering box to a 4x4 box or go crossover steering.
Get a 4x4 transmission and tcase and associated parts. Put it all in.
Its basically that, however it sounds like you're a little underinformed at the moment. Read read read and look at pics, search search search.
This is completely doable in one good solid wrench day. Just need to be prepared.
obijuan is offline   Reply With Quote
Old 07-20-2012, 11:16 AM   #12
jhaymon
jhaymon's Avatar
Re: 4wd conversion
i thought they had a post 73 blazer for 500..i guess it got sold. if you can find a clip off a 73-81 you can use the clip to do the swap. texas offroad just finished one
is it done yet?
Old 07-20-2012, 07:03 PM   #13
That Mud Truck
Re: 4wd conversion
Yeah ive been reading up on crash OK and genes builds and they loook nice.... It makes me wanna hurry up and start mine
Are the blazers the same (suspension/framewise) as the pickups?
Old 07-20-2012, 08:48 PM   #14
jhaymon
jhaymon's Avatar
Re: 4wd conversion
i wouldn't say the same, but they work well. a 73-81 is the the easiest solution. you need the axels, cross members, and hangers. ive seen it done without any welding. i dont know how i feel about that but it worked.
if you order a factory assembly manual factory assembly manual, you'll see that the 2wd and 4wd frames aren't that different.
is it done yet?
Old 07-20-2012, 08:55 PM   #15
That Mud Truck
Re: 4wd conversion
Alright so i think i know what im gonna do...
Im gonna get a th350 and a np205.... Dana 44s in the front, dana 60s in the rear... Leafs all the way around...
Just have a couple of questions. Is the th350 4x4 capable? From what ive read its unclear and will the np205 go on w/o any adapters. How will i engage the 4x4 since the prior truck is auto and a 2x4?
Old 07-20-2012, 09:01 PM   #16
That Mud Truck
Re: 4wd conversion
Also what steering box?
Old 07-21-2012, 03:53 AM   #17
andrewmp6
Re: 4wd conversion
If you use a np205 you have a small shifter in the floor to shift it in to 4 wheel low or high.On the trans i would look more at a th400 its a stronger trans then a th350.
Old 07-21-2012, 01:18 PM   #18
That Mud Truck
Re: 4wd conversion
I wold just get tcase linkage and shifter?
Whats a reasonable price for a th400? I found some from 200$-500$
None came out of a 4x4 so i guess ill have to buy some sort of rebuild kit to make it a 4x4
Theirs a couple that are heavy duty? Whats the difference
Old 07-21-2012, 04:44 PM   #19
jhaymon
jhaymon's Avatar
Re: 4wd conversion
200 is about right. never pay more for used tranny than the core is worth.
is it done yet?
Old 07-21-2012, 05:11 PM   #20
Dunenutt
Newbee
Dunenutt's Avatar
Re: 4wd conversion
Go here for the conversion to the TH400. You need to know the spline count on the transfer case.
http://www.advanceadapters.com/categ...pter-kits/191/
Check my sig for info on the conversion. I used an 85 blazer as a doner.
Dunenutt is offline   Reply With Quote
Old 07-21-2012, 05:17 PM   #21
Dunenutt
Newbee
Dunenutt's Avatar
Re: 4wd conversion
If you want to do the conversion totally aftermarket, talk to these people.
http://diy4x.com/
If you are going to beat on this truck, find a K case transmission. The bell housings are stronger. Or get an aftermarket bell housing. If it's a DD or light trail truck, a C case will be fine.
Old 07-21-2012, 05:21 PM   #22
Dunenutt
Newbee
Dunenutt's Avatar
Re: 4wd conversion
If you do crossover steering, a 2wd box is what you want. If you are using the driver side (stock) steering, a 70's-80's 4x4 box will be needed.
