07-16-2012, 10:27 AM | #1 |
Happy to be here
What did you get done? 07/15/12 edition
I haven't worked on my 77 in months. Maybe in the Fall I will feel like getting back on it.
I rebuilt my pool pump and replaced a motor, then washed all of our drivers. What did you get done?
07-16-2012, 10:35 AM | #2 |
Re: What did you get done? 07/15/12 edition
Finished up painting a customer car. Takes priority over my own stuff so when I get a break I take advantage of it.......
Had time in between jobs so I pulled the steering box off my 79 pickup to change the leaking input shaft seal that has been bugging me for months Spent a few weeks off and on building a 12 bolt rear for my wifes camaro and finally got that installed. Finished up building both differentials for the 72 blazer with all new suspension parts and got that up the street for a front end alignment. Dabble a little time between the other cars with small jobs, and changed oil in 4 of them that I've been putting off for a while. Just didn't have the time. I have more to do but I'm tired |
07-16-2012, 11:46 AM | #3 |
Hey - I fixed the cruise on Lil Red this weekend -
I was checking the oil and doing underhood inspections on all the rides this weekend and noticed the link from the vacuum diaphram to the throttle body had pulled through the little "loop" where it attaches. I welded two small washers on either side and then put it all back together - works just like brand new! I'm always happy when what I think is going to be an electrical problem turns out to have a mechanical fix. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-16-2012, 11:47 AM | #4 |
Painted the passenger door/door jamb
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
07-16-2012, 12:37 PM | #5 |
well in between Houston rainstorms.....I replaced the fuel pump module in my wifes Chevy HHR....boy was that fun
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
07-16-2012, 01:44 PM | #6 |
I pulled the exhaust manifolds from my engine as I prepare to pull the motor. I also cleaned the garage and sold a set of bucket seats. I pick up a truck box stand tonight so I can finally get it off of the jack stands and make it able to move around. I have to pull the truck out of the garage and figure where to put it since my wife is throwing a surprise birthday party for her sister in the garage this Friday. I hopeto have the engine pulled by mid August since I have so much else going on. My K5 Blazer is getting closer to getting paint on it too........ I can't wait!
RIZ |
07-16-2012, 01:51 PM | #7 |
Started prepping the TBI harness I have to go into my 84' C10. Ordered up a fuse block and some relays to wire up the ECM to 12v batt and 12v key power. It's only for a lowly 305, but I still like the reliability of the fuel injection, and I've got the entire setup just sitting here, so why not?
07-16-2012, 03:00 PM | #8 |
bought more parts for my 86 and trying to figure out if i should take the truck to the frame or not
07-16-2012, 03:45 PM | #9 |
picked up my transmission and decided it's still too hot to mess with the old girl aka project mutt
07-16-2012, 04:29 PM | #10 |
Registered Cruiser
I installed a 3 inch lift on my Uncle's 06 Tacoma.
Then cut out the center of the cab floor in my 77 to make way for the trans tunnel. It was downright humid this weekend, in the AZ
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
07-16-2012, 04:35 PM | #11 |
Buffed some paint.
07-16-2012, 06:57 PM | #12 |
It followed me home?
Got some tires installed along with some new shocks and finally got some miles on the truck.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-16-2012, 09:10 PM | #13 |
GoatLube Experss
enjoy'd be'n at home , pick'd up a 30ton shop press and clean'd up the yard.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
