07-16-2012, 07:45 PM | #1 |
14BFF Disc Brake conversion HELP
The conversion kits from ORD and DIY say to use 73-87 calipers and rotors from the front with thier kits.
Question: I have a 91 burb (2 wd). Is it safe to assume the rotors/calipers are the same as the 73-87 trucks. Any difference between a-arm and solid axle as far as the calipers/rotors? Thanks |
07-16-2012, 08:18 PM | #2 |
Re: 14BFF Disc Brake conversion HELP
that kit is designed for a 4x4 rotor. i can not say for sure if a 2wd rotor is usable, but arent they hub/rotor assemblies?
calipers i do know are the same. the only difference in 1/2 and 3/4 ton calipers is the metric or standard threads. your 91 is metric. |
07-17-2012, 09:46 AM | #3 | |
Thanks |
