Old 07-16-2012, 10:32 PM   #1
ABX131
ABX131's Avatar
Tranny Swap Question....
I pulled the th350 from my 63' and I am replacing it with another th350. The first one was dead...when I pulled the first one, I removed the 3 bolts connecting the torque converter to the flywheel before loosening the 6 bolts holding the tranny to the block. When the 3 bolts were removed the torque converter spun freely while the tranny/engine were still bolted solid together......I put the replacement tranny/torque converter and when I bolted the tranny to the block the torque converter did not spin freely like the original....Do all torque converters actually click or lock when put in? I cant get this one to click like the other and I am worried it may not be fully in place.....
ABX131 is offline   Reply With Quote
Old 07-16-2012, 10:58 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Tranny Swap Question....
Turbo 350 are required to click twice. If you don't do this, you will kill the trans and converter.
Take it apart and get it to click correctly.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-16-2012, 11:13 PM   #3
ABX131
ABX131's Avatar
It was such a Bioch to get in.... I have put long bolts in to maintain the allignment but I still cant get it to click. I do not want to drop it again....If I have to drop it I may use the other torque converter....at least I know it worked!
Old 07-17-2012, 11:25 AM   #4
chevy_mike
chevy_mike's Avatar
You should be getting the converter "clicked in" off the truck. I wouldn't even try it while in the truck as you can't get good access to push squarely while turning it.
Are you sure your new converter is for a T350? Turbo 400 converters don't lock, from what I have been told.
Old 07-17-2012, 10:19 PM   #5
ole dollor
ole dollor's Avatar
better pull it back out and make sure the converter is all the way in...it dont take much to ruin a front pump.....
ole dollor is offline   Reply With Quote
Old 07-18-2012, 08:17 PM   #6
richards72chevy
richards72chevy's Avatar
Could you guys please school me on the click.I never new about it.
richards72chevy is offline   Reply With Quote
Old 07-18-2012, 08:21 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
With the tranny out, put the TC on the input shaft and spin slowly and push in at the same time. You should feel two click and the TC will go in a little further. That will have the TC enguaged with the input shaft.
I just went thru this with my recent trany swap.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
