Not too old to learn
?????? All the holes in firewall ???????????
Took picture before tear down, right ? yes.
Put those pictures on computer ? yes. That was seven years ago.............same computer now ? well er ah ......nope. It died can't retrieve sh.......stuff ![]() All nuts and bolts and parts were labeled and bagged, but no notes on what wires, cables, pieces got through or attach to each hole in the firewall. Seems old memory faded like the computer did. I figured out some more obvious holes, like the steering shaft, master rod hole, the two square holes for main wire connectors next to the steering shaft. But that's where the brain freeze won't thaw ![]() Any one got pictures or label or reference to a diagram ?
1968 C10 a way to long restoration. |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: ?????? All the holes in firewall ???????????
Hope this helps. It's from the forum. I'm not sure who gets the credit.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
Restoration Virgin!
The above is a 69-72 cab....the 68 cab ebrake exits under the fuse block
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Thanks for the info.
One more hole not identified on mine. Under the steering column is a square hole . Can't figure what goes through there ?
This hole ? (finger) That is the Park brake cable on '67-'68 models. Just removed mine last week
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#6 | |
with the square hole then looked in my pile of parts and recognized the brake cable, even found the square grommet. Thanks rustbuket.
Restoration Virgin!
oops...I meant under the steering column hole! looks like you figured it out!
![]() Join Date: Mar 2012
nice
