Old 07-21-2012, 10:09 AM   #1
SFTorange
SFTorange's Avatar
Let's talk about wind noise
After getting my truck back on the road, I've become hyper-sensitive to the various noises it makes when I drive. I'm always waiting for something to go wrong (like when the alignment shop didn't tighten my wheel!!).
As I drive up to 45 or 50 mph, the passenger side window makes a pretty loud whistling/blowing noise. Obviously, this is a 45 year old truck, and it is going to make some noise, but I'm trying to figure out what is normal for a vehicle with new weatherstrip. Ideally, I'd like to eliminate the whistle, but I don't know if that is too much to ask.
What do you guys think? I drove around a lot of years with dry-rotted worn out weatherstrip, so I know how loud it can be!
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 07-21-2012, 10:16 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Let's talk about wind noise
Use masking tape on several areas of the window at once, drive around if it has stopped remove them one at a time until you find the culprit and see if you can adjust the seal or window...or dr seal.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-21-2012, 11:09 AM   #3
oem4me
That's a good plan, but the fact remains our trucks are about as aerodynamic as a brick. Good luck.
Old 07-21-2012, 11:25 AM   #4
PAPA KENT
PAPA KENT's Avatar
did you replace the door rubber,window channels and the fuzzies? and if you replaced the fuzzies does your door glass go all the way up into the channel?
i have the problem like i've seen listed here before that the reproduction fuzzies are indeed thicker and won't allow the door glass to go all the way up into the channel.
good luck!
PAPA KENT is offline   Reply With Quote
Old 07-21-2012, 12:54 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got new door rubber, window rubber, vent window rubber, new sound deadening added on floors and doors, as well as carpet pad, carpet and everything else.....and it will ALWAYS have wind noise.
We had a really weird air leak in the beginning, but it wasn't actually wind INTO the cab, but air evacuating out the back. My rear window bead was cut a little short, and there was a 1/4" gap in the center of the rear gasket. It made a weird sucking whistle when you drove windows open.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-21-2012, 01:24 PM   #6
TopFuel1966
TopFuel1966's Avatar
I had a lot of wind noise coming in around the top of my doors but I fixed it with a sheet of paper and a dead blow hammer. Where you suspect the air leak put the paper between the seal and the door jam with the door closed and pull on it. Where there is little or no resistance to the paper, hit the inside of the seal flange with the hammer until you have uniform resistance to the paper all the way around the door. Worked for me.
TopFuel1966 is offline   Reply With Quote
Old 07-21-2012, 11:00 PM   #7
steve'62
steve'62's Avatar
I just did the channel, fuzzies and weatherstripping. Also dynamatted/dynalinered the floor, got a huge difference!
steve'62 is offline   Reply With Quote
Old 07-22-2012, 07:49 AM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
easiest solution... turn the radio up!!
I agree with the areodynamic as a brick comment, most of the time when I drive to the yard it is against the wind, and you can feel it buffeting and holding the truck back...
when I drove my 60 series in from p.burg it was against the wind, and It got me thinking about people using these for over the road for 10 years in the 60's...
Old 07-22-2012, 04:00 PM   #9
SFTorange
SFTorange's Avatar
Thanks everyone,
My truck has new weatherstrip, fuzzies, etc. all around. It is also heavily sound deadened, insulated and carpeted. I'm sure that there will always be noise, the question is... how much?
I'm playing around with the masking tape to see if I can narrow it down.
The Brown Truck
