Old 07-23-2012, 02:18 AM   #1
dme922
dme922's Avatar
72 K-10 Pitman Arm?
I have a 72 K-10, i am trying to find out if the pitman arm off of the original manual gearbox will work on a power gearbox? Thanks for any help.
dme922 is offline   Reply With Quote
Old 07-23-2012, 09:00 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: 72 K-10 Pitman Arm?
Fellow Buckeye --- I take if you had a pitman arm from a manual K10 you would try it and see. All the listings I have seen show for a power steering gear however I have yet to find one different for a manual gear.
Can you compare the pitman shaft on the manual gear to a power gear? If the same give it a try. I have power on my 67 K10 --- I do have a spare powergear with pitman arm and rag joint but there are many out there --it is my spare from an 88 blazer -- has o-ring fittings but that can be conquered if you run across a non-sae iff.
I am guessing the pitman arm to be the same. Someone else may know for sure.
More
LMC shows 2 manual 4wd steering gears -- the 67-68 has a nut just like the 2wd's but the 69-72 shows the same style pitman shaft as a power gear which uses a bolt to tighten.
dennislbrooks is offline   Reply With Quote
Old 07-23-2012, 09:05 PM   #3
dme922
dme922's Avatar
Thanks for your input. I will give it a try and post the outcome.
Old 07-23-2012, 09:12 PM   #4
dennislbrooks
More
Old 07-23-2012, 11:56 PM   #5
MikeS.
MikeS.'s Avatar
Funny you mention a pitman arm. I put an 87 4wd axle in the front of my 63Burb mostly for the disc brakes. The axle I bought did not come with a Pitman arm I had to go hunting and searching for a Pitman arm. Called the local part houses and ordered a Pitman arm but they kept sending a 2wd version. I found the right one on eBay, cost me 30 bucks total to get it down here, well worth the money. Chevy dealer wanted 195 for it.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
