Old 10-05-2003, 09:25 PM   #26
phantom dually
Project92 SWB stepside
phantom dually's Avatar
That box is actually just a inline noise supression filter. The best thing to do is to get a test light and ground in to the chassis of the radio with the antenna unplugged. Turn the key on to see if you are getting 12v to the switched wire and to the constant power wires. If you are getting both then the radio is toast. If you are getting 12v to one and not the other then take the wire that is not getting power and tie it into the on that is. This will tell you if the radio works or not. If it does work this way there is a reason you are not getting power to this wire and almost has to be a fuse.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
