View Poll Results: which suspension for smoothest ride?
c4 vette 1 8.33%
mustang 2 8 66.67%
s10 frame 1 8.33%
other? 2 16.67%
Voters: 12. You may not vote on this poll
Old 07-24-2012, 02:03 PM   #1
whammer33024
opinion time...smoothest AD ride
been trying to decide what route i want to go. planned on doing s10 swap, but wanted other opinions. again, i'm looking for SMOOTHEST ride bagged or static. i will probably have to go static at first and save for bagging it. been seriously considering vette IFS and IRS.
what do you guys think? mustang 2, vette, or s10 frame?
whammer33024 is offline   Reply With Quote
Old 07-24-2012, 04:09 PM   #2
cajundragger
Re: opinion time...smoothest AD ride
s10 swap.
big sidewall tires.
cajundragger is offline   Reply With Quote
Old 07-24-2012, 05:52 PM   #3
mr48chev
mr48chev's Avatar
Definitely running tires with some sidewall on them either 15's or 16's at the max. I used to drive an S-10 in my last job and was never impressed with the ride of a stock truck.
Old 07-24-2012, 06:04 PM   #4
whammer33024
see 48, i drive a lowered s10 daily. its our delivery vehicle. i've grown used to having a slightly rougher ride since i've always driven lowered s10s. just wondering if there was something that was a bit smoother. i can deal with it if that's the best option
Old 07-24-2012, 06:33 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Truck arms are by far the best ride for the rear.
Old 07-24-2012, 06:40 PM   #6
Chevette
Chevette's Avatar
It's going to depend greatly on your dampening. You can install whatever IFS you want, but if you load it with a set of tight springs and shocks, you're going to stiffen the ride. I'm using a C6 with Phadt coil-overs in my TF and it's going to ride quite firm/harsh/rough....... That's not because of the C6 IFS, it's because of the coil-overs. If you're not using airbags and want a low stance, be prepared for a rougher ride, because you want to set your spring rate tight enough to keep your front fenders off the road.
Chevette is offline   Reply With Quote
Old 07-24-2012, 11:39 PM   #7
RINC
RINC's Avatar
Its a truck.
Smooth ride ? Buy a Cadillac
Chris
'69 C-20
'04 Jeep TJ
RINC is offline   Reply With Quote
Old 07-25-2012, 06:38 AM   #8
coralhead
coralhead's Avatar
Originally Posted by RINC View Post
Its a truck.
Agree
coralhead is offline   Reply With Quote
Old 07-25-2012, 10:54 AM   #9
1952ssr
1952ssr's Avatar
I'm not gonna vote cause I have never rode in any other setup other that an s10. I've had 4 s10's and 2 s10 blazers in the past 20 years, ranging from 3 inches dropped to 6 inches and have never used bags. I have used different methods and have found the best to be use spindles/coils up front but the key is in the rear..... I have found if you take the second spring out from the top that it will soften the ride and lower the truck about +/- 3 inches to boot allowing you to use smaller blocks with the rear still having ample travel. I have 40 series up front and 35's on the rear I put a pair basic monroe shocks on the front and air shocks on the rear and its very good even on the roughest of roads.
1952ssr is offline   Reply With Quote
Old 07-25-2012, 11:15 AM   #10
whammer33024
thank you for your input ssr. i too have owned several s10s that have been lowered and always thought they could be a bit smoother. i will have to consider your idea for the rear. maybe try it on my delivery truck and see what happens.
rinc, i don't see where the hostility is needed. i drive several miles around to car shows. i don't see the problem with trying to make the ride a bit more enjoyable. but thanks for your intellectual response
Old 07-25-2012, 02:10 PM   #11
youngrodder
youngrodder's Avatar
Originally Posted by cajundragger View Post
s10 swap.
big sidewall tires.
Cajun-
Do you practice what you preach? Just giving you grief.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-25-2012, 05:30 PM   #12
RINC
RINC's Avatar
Stating a fact is hostile ?
I have always assumed with lowering comes a harsher ride. Lower profile tyres, stiffer shocks, spring rates higher ect due to having less clearance.
Chris
'69 C-20
'04 Jeep TJ
Old 07-25-2012, 05:43 PM   #13
whammer33024
you should re-read post #4 in this thread. i stated i'm used to having a rougher ride. what my question was, what is the smoothest out of those options. since i lower it, should i just try to make it as rough as possible?
Old 07-25-2012, 05:54 PM   #14
RINC
RINC's Avatar
Cool. I musta read over that too fast
Chris
'69 C-20
'04 Jeep TJ
Old 07-25-2012, 07:31 PM   #15
robnolimit
robnolimit's Avatar
The 'vette parts may prove to be too wide in the end. 62" to 64" track width, tires will be outside the fender. ANY suspension, lowered out of it's geometric "sweet spot" will loose ride quality. Start with a plan that will keep the lower A-arm close to level at ride height, with a minimum of 4" compression travel from that point. I'd go with a Mustang II based IFS, and 4-bar or leafs in back.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
