Old 07-27-2012, 10:23 PM   #1
osaltyone
osaltyone's Avatar
ball joints on wrong?
Just wondering if I put these on wrong? It was the way they came, but I have seen others where the balljoint is on the other side. I think i need to flip it and the control arm
osaltyone is offline   Reply With Quote
Old 07-27-2012, 10:27 PM   #2
project 67 sub
project 67 sub's Avatar
Re: ball joints on wrong?
yes they are both on wrong, flip the arms over then put the ball joints in from the top on the other side and you should be golden
project 67 sub is offline   Reply With Quote
Old 07-27-2012, 10:28 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The ball joint normally goes on the top like you have it,... but I think you a-arm is upside down.
Got any pics further away?
edit:
I type too slow,... ha.
Keith
Convert to disc brakes.
Old 07-27-2012, 10:30 PM   #4
lolife99
lolife99's Avatar
Make sure you have the a-arms on the correct sides of your truck.
They are definitely lefts and rights.
Keith
Old 07-27-2012, 10:36 PM   #5
osaltyone
osaltyone's Avatar
they are on the correct side, one has D one P. Been running them like that for a while, but just realized the arm looked a bit off when looking from tht top. I'll filp them.
Old 07-29-2012, 03:43 PM   #6
suspect
suspect's Avatar
this is what my ride techs are showing. according to the instructions, the D & P will face down (other makers may be stamped differently). the photo is my drivers side.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 07-29-2012, 03:50 PM   #7
lolife99
lolife99's Avatar
I bet you have a big caster change when you flip them over.
Should be alot better!
Keith
Old 07-29-2012, 05:43 PM   #8
osaltyone
osaltyone's Avatar
Yep, that explains why the alignment shop could not get it right. Been Rollin the other way for a couple hundred miles. Tore it all back down for the 5.3 swap and noticed the ball at the last show others had them flipped. Couldn't find the old instructions, thanks. They have been flipped now.
