![]() My pwr locks work fine, windows no longer work. They were working last September, now nothing. Really just tired of having to mess with 'em, this may sound nuts but I'm considering wind down windows. Does it make more sense to try to get this working right, or just go manual? Is it possible to switch from pwr to manual without changing doors out? How much work/money am I looking at? Window motors are fairly new, switches are in good shape. How do I trace down window wires to my alarm to find out if the problem is connected (alarm isn't working right)? 84 swb 305 Posted via Mobile Device |
Home Built '87
Re: Switching worth the trouble...
Put some power to the motors. one wire when positive moves the window up, the other down when it gets power.
The window motor gets ground from being bolted to the door.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
I love Manual windows. I wish I had a set of 4 for my Suburban, its the only truck out of my 4 vehicles that has power doors . And guess what....They don't work. Goes down a few inches and just starts making a clicking grinding sound.
If it's a constant problem for you id say switch to manual. but check the harness and beakers/fuses first to make sure it's not a small issue. or Just install manual windows and never look back.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
Before giving up, I would just remove the plug on the end of the motor and insert a 12V tester in the motor plug ends, then operate the window switch to see if you get power when operating the window switch. My problem was that the plug at the window switch was defective and gave intermittent contact. You can still buy that plug as part of that short harness from AC Delco. My experience is that the switches are rarely the problem but are what we all replace first. I had my best luck with AC Delco motors, but I did get one with an unknown loose connector on the end of the motor - another intermittent no power situation. If you have power then it may be the regulator binding up - I went aftermarket with my regulator and it was junk, so I would stick with Delco if that was the problem - more than likely it will just be the plastic regulator wheels, but those are hard to find exact replacements and they are spot welded in place.
first see if you have power on the driver side door switch for the both sides they ground back through the switch to a common ground not the door. look at wiring diragram. it will show u how they work and what wires do what. thw two wires that go to the motor are both power and ground, depends on the way u push the switch. also check the fuse that powers it sometime its something simple.
78K & 79C Jimmys
piece of cake do go from power to manual
did that in the 88 burb found wires cracked in door opening unbolt and bolt in... only thing i regretted was waiting so long to do it oh and not having any rear motors from the factory didn't help
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Getting Old; Going Broke
If you can obtain used manual regulators to keep the costs way down it would be a worthwhile swap. Otherwise those motors are pretty dang cheap compared to a new regulator.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
So a power door on a 89 suburban already has the holes to install manual regulators???? What about the track glued to the window itself, is that the same for manual?
#9 | |
78K & 79C Jimmys
And the crank comes out where the switch goes The only issue is your drivers power door panel has a 4switch hole Posted via Mobile Device
#10 | |
The track to mount the regulator should be the same as well. |
I'm so doing this x4 on the suburban. maybe I can keep my power locks as well.
78K & 79C Jimmys
might be a gap issue,make sure to get the foam doughnut for support
my 87 burb had the crank and power locks those panels are now in the 78 jimmy with the 89 inserts to match the buckets
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-27-2012 at 01:19 PM. |
You should do a write up on this! So what did you do with the window wiring harness? Did you strip all the unnecessary wires and just make it a power lock harness?
So I would need? 4 manual window regulators 4 foam rings 4 window cranks Strip the harness to just a locking harness???? What else? ![]()
#14 | |
![]() Quote:
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
#15 |
78K & 79C Jimmys
pulled the main four bolts,push it in
between moving the window and sliding the arm , you get to a spot to remove it from the track i removed to under dash as i was going to swap this 89 to the 88 solve all the probs you see my 88 rear door ahead, turns out that switch was lock lol not window
#16 |
OK Now I am on the hunt for all the parts needed to convert from power to manual. Glad all the holes are there to make this an easy bolt in swap. This is gonna be so nice.
#17 |
Looks like the manual regulators for the rear doors are more expensive and hard to find. Are they really different or can I use front regulators on the back door's????
#18 |
Sometimes a little cleaning will do wonders. I Cleaned my motor contacts and plugs on my other 87 , and had them working again in about 20 min. These motors really hold up well. this cost me only time
#19 |
78K & 79C Jimmys
nope they are diff i think i got a front/back here in pics....
