Old 07-30-2012, 02:55 PM   #1
ozzie50
s10 swap wheels backspacing etc.
What would be the best backspacing to use on an s10 swap to move things out just a little bit, maybe cut down on such large spacers?
ozzie50 is offline   Reply With Quote
Old 07-30-2012, 03:04 PM   #2
98layinframe
98layinframe's Avatar
Re: s10 swap wheels backspacing etc.
I stuck my 18x9.5" wide with 3.5" backspacing torque thrust II's on my buddys truck and they fit almost perfect out back no spacer needed running a 4x4 s10 rearend. I say almost cause the front fender side was perfect, but the back side needs the bedside cut out with a small tub to make me feel safer then my tires sitting 1/4" away from the sheet metal.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 07-30-2012, 03:33 PM   #3
ozzie50
Sounds good I am running a 4x4 rear end also. If I went with a more narrow tire do you feel I would have to tub it with 3.5 backspace?
Old 07-30-2012, 09:17 PM   #4
chinquipin
I'm running 4wd rearend, 15x8 wheel with 3in backspacing. Running 235/75s. Works great!
1950 Chevrolet 3100
2006 Silverado Crew Cab
Some other scrap
chinquipin is offline   Reply With Quote
Old 07-30-2012, 09:18 PM   #5
ozzie50
What about in front is a 3" 3.5 move the wheels out to cut down on spacers maybe to a one inch space?
Old 07-30-2012, 09:29 PM   #6
chinquipin
15x7 in front with 1in spacer. Not sure on the backspacing on it though. Its just a stock 7in wheel from a 70 monte carlo.
1950 Chevrolet 3100
Some other scrap
