#26 | |||
Boss Hogg
![]() Join Date: Apr 2002
Re: First time welding...and I suck!
Dude, cableguy, welding in shorts and a t-shirt? Flash burns? Skin cancer? Flash burns hurt worse than sunburn. wth |
#27 |
Im mainly welding exhaust overhead. Havent had any problems other than sparks coming down. Not saying its right but when its 100+ in the shop and your under a hot car its bad enough to just wear a helmet.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#28 |
welding in shorts is ok... imo.. If i had the option to wear shorts now I would be.. too farkin' hot out lol. but i also weld on a table so my legs does see the arc so much.. just spatter falling down into my boot.. you just learn to dance while running beads.. thats all.
but yeah.. wear a helmet.. i've had flash twice... ie sand in eye balls for 2 days straight.. not that much fun. 2nd time I did learn even reflections can give it to you.. so looking away is sometimes not enough.. d'oh! I've also developed a nice case of photophobia, tho I'm not sure if it's directly related being flashed.. or in combination of tacking with eyes closed/looking away, but yeah.. photophobia.. equally fun... can't really go outside in sunlight unless i'm wearing sunglasses or i'll be squinting like a mofo while my eyes are watering something fierce.. and driving on wet roads IE glare/setting sun.. good luck lol.. deffo need sunglasses for that.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#29 |
It's Better With Nitro
You guys wearing shorts and short sleeve shirts, at least apply sunscreen. I had to add a chin flap to my welding helmet because every once in awhile tig welding upper bars of a roll cage, I would get a sunburn on my neck and throat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#30 |
I always just let the sweat run with my leather coat, gloves, mask (autodark miller) and jeans on regardless of the temperature. Sweating isn't bad for ya, it can sometimes make the work a little tougher but it beats getting burnt.
When I do overhead I find that the coat doesn't protect my nexk enough so I wear a "bib" of sorts to keep from getting sparks on my neck. Even with precautions you can get flashed once and while and when that happens it sucks!
Trevor "You already said spite" |
