Old 08-01-2012, 03:02 PM   #1
ed70
is very serious
ed70's Avatar
spindle help asap
will 90s chevy 2wd spindles work with a 67 chevy? i mean like lining up properly with balljoints and tie rods... i know 71 through 87 trucks will but havent heard anything and cant find anything about 88 and up.
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold
1970 C-10 2wd fleetside LB 307 700r4 - sold
1969 C-10 2wd fleetside LB 327 3spd - sold
1969 C-10 2wd fleetside LB 350 th350 - sold
1967 C-10 2wd fleetside LB 250 th400 -project in progress
Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed.
ed70 is offline   Reply With Quote
Old 08-01-2012, 06:01 PM   #2
SCOTI
SCOTI's Avatar
Re: spindle help asap
I haven't ever tried but I doubt it. Someone would have already done it w/these trucks being around for as long as they been.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-01-2012, 06:44 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
There are some members using the light duty 3/4 ton 88-98 stuff to put 6-lug disc brakes on the 67-87 trucks.
This requires you to run a 3/4-ton (67-87) lower a-arm (larger balljoint hole),... 88-98 upper and lower ball joints,... and 88-98 outer tie rods.
I'm not a proponent of ths swap because the spindle geometry has to be different.
Some members have done it with success.
But I remember one member spending over $600 in parts to make this swap happen.
This info is also used to run 88-98 2wd LIFT spindles,... on the 67-87 trucks.
What is the reason you want to use the '90's spindle?
What is the condition of the front end of your truck?
Adding drop spindles?
5-lug?
6-lug?
What else can you tell us.
Keith
Convert to disc brakes.
