Old 08-01-2012, 06:24 PM   #1
Denee007
Denee007's Avatar
Questions about boxing the frame
I've had a good day! It's nice to work on my truck, seems like I have no worries at all
A while back, Dave Chapman made boxing plates for me, haven't heard from him in a long time! But it was so nice of him to cut the plates for me!! So much appreciation goes out to him; )
I made these cardboard pieces and should provide a good template. I'll be welding my engine supports to the plates and hope it appears as one continuous piece of metal.
Questions if you have any comments, don't be shy)
1) how do I run my brake lines and fuel line?
2) I know I'll have to have access holes to the shock bolts.
3) when I weld in the plates, can I weld them continuously, or how?
Dne'
Denee007 is offline   Reply With Quote
Old 08-01-2012, 07:00 PM   #2
mknittle
mknittle's Avatar
Re: Questions about boxing the frame
Don't weld continuously! It will distort the frame. do it in short beads no longer than an inch long and skip around and from side to side. go in one direction It doesn't mater front to back or the other way. I did mine this way and got less than 1/10th of a degree from the front to the very back. And make double sure the frame is level front to rear and side to side. this makes it easy to check as you go. I use jackstands and sheet metal shims between the stands and frame.
You reskined your floor if i remember right. Just do it the same and don't let it get too hot. Mine was slightly bent in the rear when I started and i was able to correct it by welding 2 2" beads on the bottom rai.l so it dosent take much.
Most of all Have fun! Mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-01-2012, 09:23 PM   #3
Denee007
Denee007's Avatar
Thank you Mark! I have my truck level on adjustable jack stands so I'm good there. I hope this turns out nicely. Nothing that my angle grinder can't take care of!!
Old 08-01-2012, 09:54 PM   #4
El Campo
El Campo's Avatar
I boxed an entire 72 frame using an ARC welder. Took me like 20 hours to get it the way I liked. I'll post pictures up of how I did all my lines. It's all in my build thread link too. I welded one inch at a time and the frame turned out perfectly square even though I did it in my driveway at only 18 years of age. (got lucky)
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-01-2012, 10:25 PM   #5
mknittle
mknittle's Avatar
I don't know about luck. sounds like you were carefull to get it right.
I did mine outside with a mig fighting a intermittent breze
Mark
My GMC build.
Old 08-01-2012, 10:32 PM   #6
mknittle
mknittle's Avatar
you should be fine! Also if the plates are even with the top and bottom of the frame rail grind a chamfer on the edges to be welded to promote better penatration.
Mark
My GMC build.
