Old 08-02-2012, 12:02 AM   #1
Gregsenne
Stuck shock
I have a shock from my steering stabalizer (not the factory one but one of the two that go in front of the tie rod on the lift kit steering stabilizer) that is completely stuck. If Its on my truck, it can move, probably from the amount of force that the steering has on the shock. But if I take the shock off, there is no moving it whatsoever. The other one moves fine.
Do I need to buy a new shock or is there some way I can fix this thing? It's an oil shock I assume. The shocks are Trailmaster.
Thanks!
Gregsenne is offline   Reply With Quote
Old 08-02-2012, 12:41 AM   #2
rcbildr
rcbildr's Avatar
Re: Stuck shock
You could call the manufacturer and see what they recommend. If it were me, I would buy two new shocks so you know that they are the same and wouldn't have to worry about how that would affect things. I would think if you just bought one it would still dampen just a little different than the other.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
