Aluminum Rods
what's yall's opinion on running manley aluminum rods on the street....not a daily driver maybe drive to a local car show or work(30 miles )......
CCRider
http://www.hotrodders.com/t7799.html
http://www.earlyhemiparts.com/hemi-buildup.shtml http://www.grapeaperacing.com/GrapeA...h/rodtypes.cfm http://www.pontiacpower.com/faqs2.htm There are lots of pages on the subject...with opintions both ways. The biggest thing I saw that scared me was you are not supposed to crank an aluminum rod engine below 50 degrees...That would put me off from running them
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Ummm...NO WAY... aluminum rods have a life expectancy of around 40 1/4 mile passes. The engine must be specicially built..ie..more piston to head clearance. For the little bit of weight savings it is not worth the head aches. Aftermarket rods are cheap now(forged). A very nice set of scat or eagle H beams are 300 bucks
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
I agree. Don't use aluminum rods unless you plan on changing them after a certain amount of passes(or miles). The problem is that they grow a lot with heat and they stretch at high rpms. That's why you have to run more head to piston clearance.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
