08-05-2012, 09:53 PM | #1 |
TH200/700R4 checklist
I am going to keep my original TH400 on the shelf and run a built TH200-4R that I have. It ran 11s in a 4300lb car I had it in, so it should be up to the task.
I'm sure many have been through this kind of swap, but I'd like to accumulate a list of issues and items I need to think of. Please feel free to pile on this thread and add any info or suggestions I haven't thought of! - 4-spd column shift indicator (ordered) - carb bracket for TV cable (got one) - cooler lines (going to bend and flare my own) And a few uncertain items: - trans mount - have a new stock one, but will anything fit out of the box? - crossmember, does it need to move or do you just flip the mount around? - linkage - I'm assuming the original column shift linkage itself will work, no? - driveshaft - any mods needed? The 200 is about the same overall length as a TH350, rather than the 400. Will I need a new driveshaft, and if so, can I score something easily from a TH350 truck? - Yoke - need something to connect a TH200-4R to our driveshafts Thanks! Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-14-2013, 04:45 AM | #2 |
Re: TH200/700R4 checklist
How'd you go with this install?
02-14-2013, 03:18 PM | #3 |
I only did the chassis portion so far (no body on frame at the time). The mount I had purchased for the TH400 worked fine with the 200. Crossmember was fine. I used heavier yoke and u-joints which caused a little extra work but that was my choice.
I used a longer yoke because the 200 is a LITTLE shorter than the 400, so that compensated. Not sure if you'd need it, there's probably still lots of engagement of the yoke to trans without it but it's something to check.
02-14-2013, 03:49 PM | #4 |
Great thanks, good luck with the rest of the build.
02-14-2013, 06:11 PM | #5 |
the boat guy
If you change the trans yoke on an existing drveshaft it will need to be reballanced.
Posted via Mobile Device |
02-14-2013, 07:08 PM | #6 |
02-14-2013, 07:57 PM | #7 |
the boat guy
I want to say between $40 and $60
We usually give people a break if their shaft was ok, but they will check your yokes, ujoints and the shafts condition, stuff someone who doesn't look at driveshafts all day wouldn't notice. So its a good idea all around. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
