08-09-2012, 01:12 AM | #226 |
Re: Power Steering Adapter Plates
can u send me payment info on ps bracket and shaft kit
for 63 using a 82 pump thanks Posted via Mobile Device
///Relaxed Atmosphere |
08-09-2012, 10:57 PM | #227 |
60-66 Nut
PM sent
08-11-2012, 09:36 PM | #228 |
Sent a PM on your adapters and plates ....thanks
Ray |
08-11-2012, 11:06 PM | #229 |
60-66 Nut
Email sent as requested.
08-16-2012, 12:54 AM | #230 |
pm sent
08-16-2012, 11:10 PM | #231 |
60-66 Nut
08-22-2012, 03:38 PM | #232 |
Great parts just received them today. Top notch work thank you!! Anyone thinking about getting any of Captains parts don't hesitate you won't be disappointed!!
08-22-2012, 09:54 PM | #233 |
60-66 Nut
Thanks for the compliment and recommend
08-22-2012, 11:00 PM | #234 |
Cap, I need to purchase a power steering bracket, rag joint coupler. & brake booster adapter (all for a '66). Thanks, look foward to hearing from you.
08-23-2012, 10:15 PM | #235 |
60-66 Nut
PM sent
09-08-2012, 07:59 AM | #236 |
1961 crewcab
on a 4 wheel drive, will this work ok, or do I need an inner plate too?
btw, this is going to be for 87 4wd equipment on a 64 2wd frame..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-08-2012, 09:08 PM | #237 |
I have Factory 65 4x4, What do i need.thanks
09-08-2012, 10:34 PM | #238 |
60-66 Nut
I have sold several to guys that installed them on the '67 and earlier 4x4's. I don't think an inner plate is necessary unless you plan on wheeling it hard, and/or running big tires.
09-08-2012, 10:37 PM | #239 |
60-66 Nut
This adapter plate should be all you need unless you want the tube and flange also. Of course you will need the 4x4 power steering box, pitman arm, draglink, pump hoses, belts and pulleys for your particular engine. I don't think the template I supply for the 2wd's will work on the 4wd's, but then again I have yet to install one on a 4x4. However I do supply some pics and measurements taken from a '69 K20 to aid in the installation. If you do run into a problem I am always willing to help out via email or by phone.
09-14-2012, 05:30 PM | #240 |
PM sent for info.
09-14-2012, 10:44 PM | #241 |
60-66 Nut
09-19-2012, 12:00 PM | #242 |
Hey Cap. I'm putting in some PS in my 67 SWB and need one of your brackets.
It is a 68-72 steering box and pump...not sure the exact year.... Please send me payment info. Thanks. Armando. Posted via Mobile Device |
09-19-2012, 11:17 PM | #243 |
60-66 Nut
PM sent
09-20-2012, 12:39 AM | #244 |
Captain!
Just gotta say you're the top-notch vendor I've seen on here. Every day there's questions and BAM! - answers. You're posts are what got me hooked on the Hydro-boost setup. I went the hard way and made my own mods vs. adapters, but I still don't have it all sorted out and may just end up wishing I had used your parts. I'm hoping to catch up with you one day! Johnny
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
09-20-2012, 01:37 AM | #245 |
60-66 Nut
Thank you for the compliment Johnny
09-24-2012, 12:47 AM | #246 |
60-66 Nut
Here are a couple pics for Chvy2NV of a '67 frame mod for power steering.
09-24-2012, 01:20 PM | #247 |
Yes capt. Mine does have the little bumps from factory as the ones in the pics you posted. Please send me the payment info for the spacers.
09-24-2012, 02:11 PM | #248 |
So do these work on a 60-62?
09-24-2012, 10:45 PM | #249 |
VA72C10
Interested in a set of these for my 67 also....any issues with steering geometry (I realize it is slight). And I'm assuming they don't have to but it makes the install easier?
Looking for a 67-72 swb or blazer project in or around VA. |
09-24-2012, 11:14 PM | #250 |
