08-09-2012, 12:01 PM | #1 |
Noise that i cant find
I am not sure where to put this in the forms. When i'm driving my truck i hit the speed anywhere from 40 to 55 i start to hear this squeal squeak its not constant so i'm thinking it something that is rotating. I can feel it in my shiftier because it is a manual transmission 4 speed. I was thinking that it might be the clutch plate slipping but hesitant on changing it if that's not whats causing the sound. But like i said i'm not 100% sure its the clutch because it still engages when i drive but the clutch pedal seems to be getting a little harder to push in. Any ideas on this sound would be great I know its hard to figure out what it is with out really hearing what it is.
08-09-2012, 12:06 PM | #2 |
Re: Noise that i cant find
maybe the throw out bearing??
87 Suburban R20 (6bt Cummins) 79 Cherokee Chief (454 from Suburban) - both in progress http://lobie4x4.com |
08-09-2012, 01:09 PM | #3 |
If i pull the clutch out and look at the plate what things would i be looking for on the clutch plate if it is worn out? same thing with the throw out bearing?
08-09-2012, 07:40 PM | #4 |
Square
if you pull the clutch out don't look for anything, just replace it. same goes for anything else that easily replaceable while the trans is out.
Squarebody Syndicate |
08-09-2012, 07:54 PM | #5 |
True but i also dont want to spend money on something that is not need and i want to learn on what i am looking at if its bad or not.
08-09-2012, 08:55 PM | #6 |
Robert Olson Transport
when you change a clutch you traditionally change the throw out bearing , cut the flywheel (or replace it) and swap out your pressure plate.. anything less is a half a job.. its kinda like swapping out a timing belt and not replacing the tensioner ( and water pump if under the belt) on a rice car
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
08-09-2012, 10:58 PM | #7 |
I would say that it is probably the throw out bearing. As for stuff to replace while in there, keeping in mind a budget, just do the clutch and bearing. I have done several vehicles on the cheap and have had no troubles.
That said, on the dually I spare no expense
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
