#26 | |
![]() Join Date: Feb 2008
Re: Valve Covers
EDIT: The EBay seller is named IDAHOLIC. He has (6) sets for sale now for $ 35.95/free shipping Last edited by JJanzen; 08-15-2012 at 10:48 PM. |
#27 |
Re: Valve Covers
I also might add that I fabricated the wire loom on a CNC router. It fits under the aluminum wire holder that sits on top of the valve cover and is held in place by the two center bolts. If anyone would like the electronic file for it, I would be glad to send it.
#28 | |||
"I ain't nobody, dork."
Re: Valve Covers
![]() Gary
#29 | |
Its a Truck Thing......
Re: Valve Covers
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#30 |
Re: Valve Covers
The fuel line is 3/8" brake line that I bent with a tube bender, into an Edlebrock in-line fuel filter, into the Edlebrock 1406 fuel inlet. Here's a pict to show you a side view of the fuel inlet. The other thing that I might point out is, I am running an electric fuel pump on the red truck due to the late model 350 not having a mechancial fuel pump. The Edlebrock was a little fussy about fuel pressure, so I drilled and tapped the large nut on the fuel inlet (at the carb) and installed a fuel pressure gauge so I could determine that I had the correct pressure at the carb.
#31 |
Re: Valve Covers
I have a very similar set but for the bigblock. With a bigblock they needed to be modified to clear the brake booster, but I think with a small block you'd be OK.
Mine weren't nicely painted like the ones you posted. I wound up painting them aluminum because it's just a pain to try to keep bare aluminum looking good if you can't polish it (rough surface).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#32 |
Re: Valve Covers
omodified, very good tip! thank you!
