Old 08-12-2012, 09:31 PM   #1
arturo7
arturo7's Avatar
Accelerator Pedal Linkage
My new rig was previously stripped of the accelerator pedal and all of the linkage. I checked a couple of on-line parts suppliers but couldn't find anything.
Does anyone have an idea where I can source this?
arturo7 is offline   Reply With Quote
Old 08-12-2012, 11:02 PM   #2
TX58
Re: Accelerator Pedal Linkage
You didnt mention year truck. I bought my replacement pedal and linkage (58 apache) from classic parts. I did have to buy new hardware since it didn't come with any.
TX58 is offline   Reply With Quote
Old 08-12-2012, 11:23 PM   #3
arturo7
arturo7's Avatar
Sorry, the year is 59.
I saw the pedal and rods, but I need the whole enchilada including the shaft assembly and brackets. Did I miss something on their site?
Old 08-12-2012, 11:42 PM   #4
TX58
Part # 89-651
Linkage with rod, like I said no nuts or bolts
Old 08-13-2012, 12:32 AM   #5
arturo7
arturo7's Avatar
Hmmm...
I'm looking at the assembly manual, drawing 6-9.00, specifically, item 1) "3723534 Shaft Assembly." Is this the same part that you referenced, or am I looking at the wrong drawing for my truck? (59 Apache Panel) Or am I somehow out in left field?
Thanks for your assistance.
Old 08-13-2012, 02:48 PM   #6
_Ogre
_Ogre's Avatar
this is from my 58, there should be a hole and a flat spot in the motor bump out for this to attach to
all you will need is a bar to connect the linkage to the carb
free, yours for the asking
shop air compressor timer
Old 08-13-2012, 03:47 PM   #7
AZ59apacheguy
It depends on what engine you have. The linkage setup is different from an inline six to a V8
AZ59apacheguy is offline   Reply With Quote
Old 08-13-2012, 05:48 PM   #8
arturo7
arturo7's Avatar
Here is a low quality shot of the floor. I'll post a better one tomorrow. If that is the correct part I will gladly accept your offer.
At this point, there is no motor. It will either be a Chevy 350 or Mercedes diesel.
Old 08-13-2012, 11:19 PM   #9
TX58
It's different then. Mine doesn't look anything like that.
Old 08-13-2012, 11:37 PM   #10
OrrieG
OrrieG's Avatar
I have the one like orge in my truck. it is the stock v-8 setup. Here is what it looks like installed. I made the rod between the pivot and carb. The stock set up has a pedal with a pivot attached to the floor and pedal that clips into the pivot.
Old 08-13-2012, 11:45 PM   #11
arturo7
arturo7's Avatar
I need to take a look closer look at the truck tomorrow.
...and the possibility of the Mercedes OM6617 is pretty remote. It's not economically feasible to rebuild one, and the thought of installing a 20 year old junk yard motor scares me.
Old 08-14-2012, 05:39 PM   #12
arturo7
arturo7's Avatar
Here is a better shot of the firewall, both sides.
Old 08-14-2012, 05:59 PM   #13
arturo7
arturo7's Avatar
While I was taking the above pics I was told that a box of parts arrived with the truck. Below is one of those parts. It looks close to the assembly in that manual except for the piece with the rubber on it. This aperture is not shown in the drawing. Any thoughts?
Old 08-14-2012, 06:07 PM   #14
_Ogre
_Ogre's Avatar
the oval slot in the insulation is where this goes, 4'' above the other hole,
bracket was installed on the inside of the cab
truk was an original v8 truck
Old 08-14-2012, 06:09 PM   #15
_Ogre
_Ogre's Avatar
that would be your starter linkage for the 6 cyl foot starter
i tried to modify one to work with a v8, didn't work
Old 08-14-2012, 06:11 PM   #16
arturo7
arturo7's Avatar
Very good, sir! I would love to have the part that you posted above. PM on the way.
