08-13-2012, 12:41 PM | #1 |
350 vs 700r4 length
I tried the search before I asked, but couldnt find an answer. My 74 shortbed originally came with a 350/350 combo. They are both long gone now. I have a 400 to install but now might be trading it for a 700r4. Im guessing my 350 had a 9" tail shaft but not sure. Am I going to need to lengthen or shorten my drive shaft?? Is the column shift brackets going to adapt or do I need them from an 80s truck?? Thanks for any info, Matt.
08-13-2012, 12:46 PM | #2 |
yeller
Re: 350 vs 700r4 length
my 73 C10 came with a th350, I swapped a 700 in, the drivesahft did not need to be shortened at all.
Can't help on the linkige part, I am running a floor shifter.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 08-13-2012 at 12:54 PM. |
08-13-2012, 12:53 PM | #3 |
Drive shaft and the linkage will both work.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
08-13-2012, 01:45 PM | #4 |
You do have to move the cross member..
08-13-2012, 05:27 PM | #5 |
Well if my stock driveshaft will work that will save me some coin. Thanks for the info.
08-13-2012, 06:17 PM | #6 |
Slots go on anything!
My '74 had the long tailshaft, and the 700R4 went right in. I did have to move the crossmember, like Rich mentioned. Not an issue at all. Driveshaft and linkage works like a charm.
1974 Jimmy- 5.3/4L80e/NP241 |
08-13-2012, 06:31 PM | #7 |
If your truck had a long shaft TH350 then you don't need to do anything, the driveshaft slip right in. How do I know, my 1974 was an original TH350 (they originally came with long shafts) and I put in a 700R4 and used the original drivesaft.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
08-13-2012, 07:12 PM | #8 |
I dont remember if my 350 was a long tail or not. Does one of you have a measurement of the driveshaft?
08-13-2012, 08:50 PM | #9 |
A "short tail" TH350's extention housing is roughly 6" long.
A "long tail" TH350's extention housing is roughly 9" long. |
08-14-2012, 12:45 AM | #10 |
08-14-2012, 01:57 AM | #11 |
Linkage should work just fine. Just need to change the indicator in the dash. Easy swap.
08-14-2012, 07:47 AM | #12 |
BAD BOW-Silverado XST
Transmission mounting and housing sizes.
http://www.tciauto.com/tc/trans-dim |
08-14-2012, 01:38 PM | #13 |
If you can wait a bit I can slide under my truck and measure the driveshaft on my truck.
08-14-2012, 01:59 PM | #14 | |
08-14-2012, 02:00 PM | #15 |
08-14-2012, 02:02 PM | #16 |
08-14-2012, 02:21 PM | #17 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
08-14-2012, 03:10 PM | #18 |
If that option doesn't pan out, LMC truck (cheapest) has them along with a few others. On Ebay: http://www.ebay.com/itm/GMC-C-K-R-V-...item53ec2202a7 Classic Industries: http://www.classicindustries.com/truck/parts/17140.html LMC: http://www.lmctruck.com/icatalog/cc/full.aspx?Page=136 (It says it is for later models than yours but that is only due to the availability of the 700, it will mount just fine with no mods) Or, Yes, Junkyard but if you are like me, you most likely will leave the junkyard with it and a host of other parts you found and an empty wallet.... |
08-14-2012, 04:14 PM | #19 |
i dropped a built 1966 327 ci engine with a 1997 4l60e in a 1986 c-10 that had a 305 ci and a th350 and all I had to do was move the cross member and the shifter worked fine also
08-14-2012, 04:16 PM | #20 |
