Old 08-17-2012, 12:34 PM   #51
VA72C10
VA72C10
VA72C10's Avatar
Re: Project#1: Bright Horizons - 68 Swb on Air
Originally Posted by ccracin View Post
I can't believe I am just seeing this! Good for you man! You and I have some similar thoughts. I am in the process of getting a side business off the ground. I'm not getting into restoration, but providing parts solutions. I don't want to jack your thread, hit me up if you want to talk about it. I wish you all the best maybe we will collaborate at some point!
Thanks, hope we can collaborate on some cool parts. Sent you a pm to discuss some ideas I have...
I haven't been able to make it down to the body shop. He's been busy so no room to work on it there with other vehicles in the way...
I've also had a lot of family activities (2 birthdays) and responsibilities around the house plus been working on several consoles and tach dashes I've sold.
Will try to at least get the parts laid out and pictures taken by the beginning of next week.
Old 08-17-2012, 12:41 PM   #52
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Cant wait to see ya get the new venture up and running..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-17-2012, 02:56 PM   #53
Tinkermc
Maybe I'm old fashened but I still like pictures, good luck Johnathon
Tinkermc is offline   Reply With Quote
Old 08-17-2012, 11:02 PM   #54
VA72C10
VA72C10
VA72C10's Avatar
Thanks!
I know... going to take some pictures of the parts gathered hopefully this weekend.
Old 08-18-2012, 12:35 AM   #55
68 Four on the Floor
68 Four on the Floor's Avatar
Looks like an awesome starting point. Congrats on the new business venture. Wish i could do the same
68 Four on the Floor is offline   Reply With Quote
Old 08-18-2012, 10:25 PM   #56
VA72C10
VA72C10
VA72C10's Avatar
Thanks, hoped to have time to lay out all the parts today but ended up finally getting help and good weather (rain was forecast but was a nice day) to be able to fix my home's storm damage....
For those that hadn't seen...the June 30th derecho dropped a tree on my house that thankfully only damaged the soffits and gutters and a couple small areas of the roof...
Old 08-18-2012, 10:40 PM   #57
VA72C10
VA72C10
VA72C10's Avatar
I still haven't received the insurance money yet (waiting on the mortgage company to sign off on the check)...but have been doing my best to get things fixed...got the tree cleared out (mostly by myself with help from my father)...caught a guy cutting trees at a neighbors yard and got a good deal felling the rest of the tree and they hauled it away...
Today came the real work. My father came over to help me by not only handing (throwing) the tools up to me on the ladder but had a great idea (more on that in a bit) and helped hold the boards up and a lot more....couldn't have done it without him!
Found a hole in the porch roof I had missed from the ground so I had to remove an area of shingles, fix the hole from the inside, seal it, and reinstall the shingles. Thankfully it's completely separate from the house and no water damage has been caused at all and now it's sealed. Got the facia board removed and replaced, put up the decorative facia and fixed the broken ceiling of the porch and the damaged first two rows of shingles. Thankful I found a good match at Home depot.
Still have to caulk and do some painting and then the leafguard gutters will be replaced but it's watertight for now!
Old 08-18-2012, 10:41 PM   #58
babyblueoval
babyblueoval's Avatar
YIKES!!!
Dude, glad you and you're family are ok and the damage wasn't any worse.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 08-18-2012, 10:41 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
The main challenge came at the center of the main portion of the house where the tree hit. It had crushed the plywood , tore the shingles and tar paper, and broke the end off one of the rafters. So I had to repair that before fixing the soffits obviously.
That's where my dad's great idea comes into play and where this is "somewhat relevant" to trucks
disclaimer....don't laugh....it worked
He asked if we could somehow use one of my jacks to jack up the damaged section. So we started with a bottle jack but it was too tight to get in the space even with it all the way lowered. Next...we started using engineering....redneck engineering
I've actually helped a brother in law jack up his home using a large jack and a piece of wood so I thought...why not?
this is way up there...18 feet.....
soooo...what can we find???
Well, I built a deck a couple years ago and have some extra lumber under the deck so out comes a 4x4x12 post....
still a little short....
so....
Old 08-18-2012, 10:41 PM   #60
VA72C10
VA72C10
VA72C10's Avatar
In case anyone else has a trilevel house and is wondering...it takes three 8" rally wheels (5 lug preferred ) and one 6" rally wheel/tire to get to the proper level
Here's the finished product.....with my father proud of our invention
And it worked flawlessly. Rotated the jack to move from one area to the next and added some bracing to keep the plywood solid. Then added the facia...actually got everything done with the white decorative board but forgot to take pictures...
I did take one more picture though....I walked back to eyeball the roof line to make sure we had it jacked up to the right height and on my way back the handle on the jack was down at about eye level as I looked up.....
...just about took out my eye...thankfully only blunt trauma on my forehead and a slight scratch on my nose....could have been a lot worse...
Old 08-18-2012, 11:11 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
You can see the jack handle down about my eye level in the picture...makes my head hurt just looking at it
You can also see that roof work is dirty
Old 08-18-2012, 11:15 PM   #62
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by babyblueoval View Post
YIKES!!!
Thanks, we feel grateful! I should have been walking up the front porch about when that railing got smushed like that...but a tree in the road kept me away for 1/2 hour until the storm was over and we could move the tree...
Old 08-19-2012, 01:44 AM   #63
1972BackInBlackC10
1972BackInBlackC10's Avatar
yooooou might be a red neck if.......... lol
1972BackInBlackC10 is offline   Reply With Quote
Old 08-19-2012, 01:57 AM   #64
68 TT
Still plays with trucks
68 TT's Avatar
Glad you are getting to do something you love for a living. I wish you the best of luck in making it work out for you.
I may do the same thing in a couple years.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-19-2012, 01:59 AM   #65
Chvy2NV
Good things you guys are ok. Way to get creative
Chvy2NV is offline   Reply With Quote
Old 08-19-2012, 04:04 PM   #66
Tinkermc
glad you and your family were not hurt, you should have called me. When do you get the truck back from the body shop?
Old 08-19-2012, 08:47 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
thanks, I am going over there tomorrow. Have some interest in the bed on there currently. It will be over there for a while...at least the cab will....trying to decide how to best keep that there...
Old 08-19-2012, 11:42 PM   #68
butternut1972
butternut1972's Avatar
Hey good luck on the new venture...That's a great job to have.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 08-20-2012, 04:38 AM   #69
VA72C10
VA72C10
VA72C10's Avatar
Thanks!
Here are some pictures of parts gathered. These are some of the engine related and under-hood items.
New CPP booster/master/bracket/prop valve/lines setup
New ceramic coated headers with collectors
Rebuilt 73-up motor mounts (very similar to 72 bb mounts) for header clearance...stripped/painted/new rubber in the mounts.
Clutch fan (one pictured is actually too big but I have another one)
Perfect fan shroud
Rad cover (going to tweak this one or custom make something)
powdercoated 68 center latch support
NOS black plastic washer jug (corvette option truck now )
Holley 570 carb with stainless dual feed fuel line lightly used from this forum
Old 08-20-2012, 04:43 AM   #70
VA72C10
VA72C10
VA72C10's Avatar
More pictures...
Old 08-20-2012, 04:49 AM   #71
VA72C10
VA72C10
VA72C10's Avatar
Oh....and a finished shot of the house (before caulking and paint touch ups...)
Need to power wash the house still and plan to clean the roof also so the new shingles don't stick out so much....color match is actually good but the old ones have tree dirt/mold on them so the new ones look a lot lighter...also need a couple good hot, sunny days for the shingles to lay back down...but once the gutters are up; the shingles shouldn't be that noticeable at all anyways...
Old 08-21-2012, 01:10 AM   #72
VA72C10
VA72C10
VA72C10's Avatar
All those pictures and no comments?
Okay, some progress on the truck today! Got the bed unloaded, cleaned out, and the started repairs. Have one more spot to finish then some grinding and primer to protect it then some dents to work out. Going back tomorrow to hopefully finish.
Old 08-21-2012, 01:12 AM   #73
VA72C10
VA72C10
VA72C10's Avatar
Here are the bed repairs.....bad areas before....
Old 08-21-2012, 01:14 AM   #74
VA72C10
VA72C10
VA72C10's Avatar
And during.....after to come tomorrow. Worst area I need to take pics of.
Old 08-21-2012, 01:25 AM   #75
Jastos
OK now I am officially excited. No more injuring yourself!
Jastos is offline   Reply With Quote
