Old 08-18-2012, 12:50 AM   #1
tow guys
tow guys's Avatar
Can anyone identify this part??
We removed it from the truck, specifically the front driver's side corner of the intake manifold, over a year and a half ago and now have no idea what it was for. Any ideas??
EDIT! This was not removed from front driver's side corner of intake. It appeared that way in a photo but upon closer examination, this is incorrect. We're back to square 1 on this one. I have no idea
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 08-18-2012, 12:59 AM   #2
whoryou1979
whoryou1979's Avatar
Re: Can anyone identify this part??
Maybe a lifting eye?
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 08-18-2012, 01:03 AM   #3
tow guys
tow guys's Avatar
It seems to have a bevel to the hole in the center which indicates it had a real purpose. The motor already had 2 lifting brackets besides this one so I doubt that's all it was used for but ya never know lol
Old 08-18-2012, 01:14 AM   #4
whoryou1979
I have a similar one at the left rear of my intake, but it has a square hole in it to run the kick down cable through.
All Day Every Day
Old 08-18-2012, 01:24 AM   #5
tow guys
tow guys's Avatar
Interesting....our truck is a 4 speed so no kick down cable here but we're getting warmer...
Old 08-18-2012, 06:54 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Talking Re: Can anyone identify this part??
Might be to route a power brake or PCV hose through? It appears to have a hole for an accelerator spring.
That's my guess anyway.
What does the winner get?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-18-2012, 11:14 AM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
X2 Exactly what I thought too. My '72 K5 Blazer had one of those on the driver's rear of the engine where the vacuum booster hose passed through.
DirtyLarry is offline   Reply With Quote
Old 08-18-2012, 11:17 AM   #8
tow guys
tow guys's Avatar
Bob, the accelerator spring part makes sense but I'm trying to determine what the large tapered hole is for. For the life of me I can't remember what it was used for and it looks kinda important and I'd like to reinstall it if I could
Old 08-18-2012, 11:19 AM   #9
tow guys
tow guys's Avatar
Anyone have a pic of this part installed so I can use it to compare notes??
Old 08-18-2012, 12:44 PM   #10
DirtyLarry
DirtyLarry's Avatar
Sorry, not me. Sold the K5 in 1993
Old 08-18-2012, 12:55 PM   #11
jaros44sr
jaros44sr's Avatar
Did your truck have cruise control? Or, the factory cable to keep the engine from shifting to one side on acceleration, but i think that was on the passenger side...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-18-2012, 01:13 PM   #12
I also believe it's for the vacuum line to the brake booster
Old 08-19-2012, 07:01 AM   #13
bobs409
bobs409's Avatar
I have a bracket on ebay from an Impala. You'll notice the hole is the same. It had the power brake hose going through it. See it here:
http://www.ebay.com/itm/71-72-73-74-...item231f83065b
Sometimes they have a rubber grommet in that hole too.
Bob
Old 08-19-2012, 08:28 AM   #14
Steve Hafner
Steve Hafner's Avatar
In the center of the first picture below, there's a bare metal part with a rubber grommet inside of the hole. This was said to be from a 72 with 10,000 miles.
In the upper right corner of the second picture, from a 70 GMC, you can see a bare metal ring with a hose going through it.
Could it be one of these ?
Steve Hafner is offline   Reply With Quote
Old 08-19-2012, 09:20 AM   #15
tow guys
tow guys's Avatar
Steve, it looks like your second pic is spot on as it came from a 70 GMC. Apparently it is for the brake booster hose.
Thanks everyone for another session of knowledge. I suppose I should blast and paint this part for when the booster gets reinstalled huh?
Tony
Old 08-19-2012, 10:15 AM   #16
Steve Hafner
Here's the entire picture . . . it was from an original, low mileage 4X4 Suburban.
Maybe you can blast it and just spray clear coat on it, since it looks like it was bare metal when installed at the factory.
When you put the black hose through, it will stand out as a rare part, most engines don't have !!!
Old 08-23-2012, 06:01 PM   #17
mdeprimo271
It is for the brake booster hose. It keeps it away from the throttle linkage, so it won't interfere with it.
mdeprimo271 is offline   Reply With Quote
Old 08-23-2012, 09:08 PM   #18
Tinkermc
just lovi it when a mystery is solved
Tinkermc is offline   Reply With Quote
Old 08-23-2012, 09:31 PM   #19
tow guys
tow guys's Avatar
Thanks fellas. It'll be getting the media blast and paint treatment before reinstallation
Old 08-23-2012, 10:45 PM   #20
bollybib
bollybib's Avatar
I'm getting ready to retrofit mine with a booster and I was wonderin' if there was something stock that supported the vac hose and here it is !
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
