transmission help
when i put my truck in reverse it takes 3-4 seconds for it to engage. even when it is warm. the transmission is a th350. it only started this after we rebuilt my motor and put on 33 inch tires. is my transmission going bad? when it finally does engage it kicks in pretty hard
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
changed transmission filter
i changed the filter and it is still the same, the fluid level wasnt low or anything the fluid was a little dirty but not really bad
Insert Witty Text Here
I had one do that once. It eventually went out when I changed the fluid (within a couple of days...). The transmission shop said it was an internal seal that went out. I don't know if that is relevant to your problem, though.
Slonaker |
My TH400 went out awhile back and the first symptom of that was that it took awhile to go into reverse in cooler temps. I had changed the fluid and filter also, and it didn't help.
Scott Shelbourne |
Robert Olson Transport
![]() Join Date: Oct 2002
sounds like the transmission is on its way south. as long as the fluid level is good aint much ya can do for it except save your pennies and buy a new one
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
thats what i thought is was
you guys were supposed to say that the transmission is fine and it was something small and cheap going out. i kind of figured it was the transmission. i'll have to start saving up. anybody know of a good site with directions to rebuild it
thanks stan
