08-21-2012, 09:41 PM | #1 |
Exhaust manifolds
Who sells new exhaust manifolds for inline engines? I have found some on ebay and other sites, but they do not have the heat riser. I really don't want to modify my intake with a water heat plate or go with headers, as my exhaust system is fairly new.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-21-2012, 11:04 PM | #2 |
Re: Exhaust manifolds
bump
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-22-2012, 08:56 AM | #3 |
I am a Referee of life.
I don't know new.I had one with broken studs and a somewhat eaten up flange at the exhuast pipe.I went to the wrecking yard nd found a decent one.It also had a couple bad studs.I cleaned it up,drilled,worked out the bad studs and replaced them with new and painted with VHT cast iron paint.I didn't find a new "donut saver" and need to.The donut saver is a slightly smaller diameter flanged pipe that fits into the exhuast pipe and has a taper at the top.It helps center the donut and keeps the donut from burning out so esily.Keep yours or get one if you can.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-22-2012, 12:59 PM | #4 |
RockAuto is hit and miss for that part, but they're currently showing 1 left in stock for $159: http://www.rockauto.com/catalog/rafr...&parttype=5860
I remember finding a couple of other sources for one when I was looking for my little 230, I'll see if I can dig them up and post them. Hope that helps.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
08-22-2012, 01:16 PM | #5 | |
Go to Corvette Central and search for "exhaust donut sleeve" or try these guys https://www.paragoncorvette.com/c-23...ange-assy.aspx
08-22-2012, 03:51 PM | #6 |
I believe LMC has them.
