Old 10-09-2003, 02:57 PM   #1
useRc10
useRc10's Avatar
installing edelbrock carb?
I'm installing a used edelbrock carb on my 305...do the mounting bolts need to be torqued or just tightened? also, how do you do adjustments on the 1406 carb?
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 10-09-2003, 03:04 PM   #2
79Chevypickup
MY TRUCK IS FOR SALE!!
79Chevypickup's Avatar
I just did the same thing yesterday!!!
Did you use the spacer?
or
Did you not have too?
I tightened them down untill Icouldnt turn them
anymore, to make sure I would have that perfect fit....
As far as adjusting, what exactly do you mean?
I had to adjust the timing and idel screw once I put
mine on, but thats the easy part...
As far as adjusting the gas and oil screws...
I dont really know, except someone once told me that
you have to turn them a little at a time and accelerate the
engine, look for smoke or color of smoke and smell the
exaust for either to much oil or gas...
But thats the backyard way to do it...
Thats how I did mine...
Kind of a teadious project....
Hope I could help!!
1979 Chevy LWB
350ci / 700R4
Edelbrock under the hood
F O R S A L E OR T R A D E
79Chevypickup is offline   Reply With Quote
Old 10-09-2003, 05:28 PM   #3
1FaastC10
1FaastC10's Avatar
i'm curious. where are the oil screws on a 1406?
1FaastC10 is offline   Reply With Quote
Old 10-09-2003, 06:35 PM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Best way to tune it is to take a screwdriver and tighten one screw on the front first to where the engine starts to stumble. Then back about 1/2 turn. Repeat this on the other side screw and repeat till you think it's balanced out right.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-09-2003, 11:38 PM   #5
TX_Mudder
Do NOT overtroque the mounting nuts. The base of your carb is aluminum and you can warp it. Say hello to vacuum leaks and possibly a gas leak.
I forget the exact torque figure, but there is oen out there. I'd say 20 ft lbs is plenty, along with a start washer or lock washer.
Better you have to retighten them a little because they loosen up vs. buying another $250 carb.
-- Mike
TX_Mudder is offline   Reply With Quote
