Closed Thread
Old 08-23-2012, 10:34 AM   #1151
1project2many
Re: What Did You Do With Your Truck Today ?
Also need to find a new seat. I need the room to fit my little fat arse behind the wheel.
Funny. Prolly want to pull that tank for extra room, no?
I'm headed out to do some tuning on mine.
1project2many is offline
Old 08-24-2012, 08:45 PM   #1152
mknittle
mknittle's Avatar
I welded my home made kick panel patch in. Man it was a murphys law morning It came out ok though. hopefully the other side will go easier
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 08-24-2012, 10:01 PM   #1153
weaintscared
weaintscared's Avatar
Got motor today
My build http://www.67-72chevytrucks.com/vboa...32#post5555832
weaintscared is offline
Old 08-25-2012, 03:24 PM   #1154
Russell Ashley
Russell Ashley's Avatar
I put a new latch and stricker plate on my drivers side. I also re-painted the door panels while they were off to correct the hurry-up job I did the first time.
Then I actually used it. I went to Lowes and got a dozen bags of bark chips
Russell Ashley is offline
Old 08-26-2012, 02:38 AM   #1155
RINC
RINC's Avatar
Sweet ! Russell thats a purdy truck all loaded up !
Well today I called in a roll-back to give mine a lift to the shop
Now all snug as pig stuffed in a blanket
Ha ! Its nice to post a pic of it other than in me driveway
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 08-26-2012, 08:31 AM   #1156
FRED 53
Got my 8 month project BEATER -patina truck done just in time for our 4 day rod run--went well performed well in the 30 mile parade--all new frame-off build with all original sheet metal put back on--( now time to sell it )--start another project
FRED 53 is offline
Old 08-26-2012, 10:03 AM   #1157
beanyard
I went to pick up Sheetrock in mine and they said "you arent putting it in there are ya?". The funny thing is that it hauls more than a modern 1/2 ton.
1959 Fleetside Big Window Long Box
Standard Trim soon to be Deluxe
1953 GMC Carryall Suburban
beanyard is offline
Old 08-26-2012, 09:07 PM   #1158
OrrieG
OrrieG's Avatar
This weekend scored two cheap speakers for the kicks ($5) so I will be able to upolster them. Found a NOS Trico Wiper squirted setup for 55-59 in my dads stuff ; will sell it to a stock restoration fanatic and get an electric set up for mine. Also finished modifying the VA under dash diffusers. Decided I am over thinking my ac hoses, tomorrow getting some grommets and cutting holes to stuff the hoses thru, worst case is I will be filling holes back in but not in the firewall.
OrrieG is offline
Old 08-26-2012, 09:32 PM   #1159
hotrod1
56 - autocross
hotrod1's Avatar
Look up "ac hose bulkhead" in google images. U will see many solutions
hotrod1 is offline
Old 08-27-2012, 12:39 AM   #1160
arturo7
arturo7's Avatar
Went downtown for a couple cold ones. Showed some buddies pics of my truck. They all laughed. A lot.
I''ll show 'em...
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 08-28-2012, 10:10 PM   #1161
danheit
danheit's Avatar
Built my rear body mounts for the new frame. Just need to work out my fronts and I am on the short track to being on the road!
danheit is offline
Old 08-29-2012, 12:33 AM   #1162
oldcouple
oldcouple's Avatar
Figured out why my brake lights were not working, the original switch had died. How did one person install that thing? Had to grind off the screw heads inside the cab and drive it out, will put the screws in from the bottom and add nuts to the inside. Duct tape to the rescue to hold it in place till I can bolt it down.
Retired and too busy to work.
oldcouple is offline
Old 08-29-2012, 12:43 AM   #1163
Daze57
Daze57's Avatar
workin on dem dar relays to hookin up my sidewinder 'lectric fan - boy does dat pull some air in !
Daze57 is offline
Old 08-29-2012, 06:36 PM   #1164
pvienneau
pvienneau's Avatar
Did my first weld job for the drivers side corner bracket that supports the seat frame on my 49 project. Lots of grinding and making holes. All in all I think it is strong but not pretty.
pvienneau is offline
Old 08-29-2012, 08:10 PM   #1165
OrrieG
OrrieG's Avatar
Hot glue, holds it in place but peals right off. Wife taught me that.
OrrieG is offline
Old 08-29-2012, 08:11 PM   #1166
OrrieG
OrrieG's Avatar
I''ll show 'em...
Bet they drive Honda's, Toyota's and Suburus????
OrrieG is offline
Old 08-29-2012, 08:16 PM   #1167
Chevette
Chevette's Avatar
Russell: Your truck looks great! The wheels and wide whites really suit your truck. Very Cool.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline
Old 08-29-2012, 08:39 PM   #1168
la hi
I added a front sway bar to the 57 chevy. I will add the rear tomorow. Then I will look at the tracton master and see if I need that.
la hi is offline
Old 08-31-2012, 05:40 PM   #1169
Russell Ashley
I installed my compressor and alternator mount. It moves the alternator to the drivers side and mounts the compressor where the alternator used to be. The compressor lines up with the crank and water pump pulleys but it looks like I will need a water pump pulley with an additional groove to make the alternator belt work.
Old 08-31-2012, 10:11 PM   #1170
Daze57
Daze57's Avatar
I''ll show 'em...
no offense sir but ask your buddies if they even know what they are lookin at !
Daze57 is offline
Old 08-31-2012, 10:32 PM   #1171
arturo7
arturo7's Avatar
It was all in fun, and no, they had no idea.
ever forward
arturo7 is offline
Old 09-01-2012, 09:19 PM   #1172
waybad
waybad's Avatar
put new motor mounts in, bent the pan.... took the pan off.. fixed the dent..new gaskets,,,
leaked like the there were no gaskets,,, bought more gaskets,,,,, installed the gaskets to the block!!!!!! no leaks..whew!!!(YES).... fix one problem,,,,, create new problem,,, all in a LONG DAYS work... URGH>>>>>>>>>>>>>>>>>>
then check craigslist,,,, free Avalanche seat!! big time score!! hopefully?????
waybad is offline
Old 09-02-2012, 01:30 PM   #1173
Docs fitty6
Fuel filter/pump and fuel lines w/press. gauge done, B&M ratchet shifter done, E-brake..done, fenderwell headers 'almost' done, wiring done, upholstery done, steering done, suspension done, radiator connected and filled, oil in engine and used an old dizzy drive to convert to a priming tool and primed the engine. (will do that again prior to fire up and break in). Put a newer, longer tranny fill tube in as well. Had to resort to 195-45 15 tires to clear the headers!
Bleeding the brakes is next and then a bit of exhaust work...should get me to the point of firing it off.
later
Docs fitty6 is offline
Old 09-02-2012, 05:47 PM   #1174
lowdownstar
big guy
lowdownstar's Avatar
I installed my flow masters today and the truck sounds great to bad my wife asked for a divorce, and left me.
Ray
lowdownstar is offline
Old 09-02-2012, 11:44 PM   #1175
nvrdone
Got the brakes fixed & took it to a local show. First time on the road in about 8 years. Sure felt good.
nvrdone is offline
Closed Thread
