08-23-2012, 02:27 PM | #1 |
alternator wiring
Hey guys
I'm using the psi harness for my swap. The harness has 1 wire going to the alt connector, I guess controlled by the PCM. Do I just run a 12v power wire from the back of the alt to either the pos+ starter lug or pos+ side of battery? and I'm done? thanks Posted via Mobile Device |
08-23-2012, 08:06 PM | #2 |
Re: alternator wiring
Should work, Most LS1 F-bodies are wired that way.
08-23-2012, 10:27 PM | #3 |
thanks clinebarger.
I'm running it to the starter. Just now putting the finishing touches on the swap. I'm ready to drive this thing already!! |
08-24-2012, 01:10 PM | #4 |
I would use at least a 10 gauge wire for it too.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-24-2012, 01:14 PM | #5 |
will do. I've got some 4g waitin to go on.
thanks for the help guys Posted via Mobile Device |
08-26-2012, 09:45 PM | #6 |
I wired mine that way as well..also have a psi harness...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
09-02-2012, 12:13 PM | #7 |
A day late and $1 short...
I too have the PSI harness. How did you all wire the power to the cab? The voltage regulator goes away and leaves a brown and red wire. The red wire is a branch off of the red wire that goes to the back of the Alt, so I figure I can delete it. But what do I do with the brown wire?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
09-02-2012, 08:52 PM | #8 | |
09-02-2012, 09:37 PM | #9 |
Cool, thanks! I am too nervous about cutting out something I may need later!
12-02-2012, 10:20 PM | #10 |
I've got the psi harness too. It came with a 4 pire plug with only 1 wire in it. Is this the alternator plug? I have a alternator that has a 2 wire plug and a post for positive on the back Can I change the connector
12-03-2012, 09:11 PM | #11 | |
12-07-2012, 10:23 PM | #12 |
I found out I have a LS truck alternator I think one wire is for the exciter and one for the gauge. I got the plug from my factory harness and used 1 of the wires for the exciter Hopefully it will be running in the next week and Ill see if it charges
04-18-2013, 11:48 PM | #13 | |
You reused the original red wire going to the back of the alternator and then just removed all 4 branch wires going to the old regulator? The original wire the went to the back of the old alt. was basically a wore that ran back to the junction block on the passenger fender across the core support? Posted via Mobile Device |
04-19-2013, 12:08 AM | #14 |
Seems correct to me.
04-19-2013, 12:10 AM | #15 |
04-19-2013, 12:22 AM | #16 |
Yep, basically I ended up with the red wire coming off the alternator to the junction where the regulator was then splitting off with one side going to the firewall and the other going to the positive side of the battery (through the junction block on the fender).
