Old 08-23-2012, 07:26 PM   #1
oldcouple
oldcouple's Avatar
Step side step brace
Installing the little things on my 56, I have two braces that attach to the steps, but cannot find where the other threaded end should attach, any ideas?
The brace is item 3 in the LMC cat, I circled the end (bolt and washer 7&8) I am unsure of in red. Photos would help..
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 08-23-2012, 08:45 PM   #2
starterman99
starterman99's Avatar
Re: Step side step brace
they bolt thru a hole in frame
1950 5 window
starterman99 is offline   Reply With Quote
Old 08-24-2012, 11:54 AM   #3
_Ogre
_Ogre's Avatar
maybe this will help
shop air compressor timer
Old 08-24-2012, 08:30 PM   #4
Daze57
Daze57's Avatar
hmmmmmmmmmmmmmmm -- i aint got dem either !!!!
Daze57 is offline   Reply With Quote
Old 08-25-2012, 01:28 PM   #5
oldcouple
oldcouple's Avatar
Thanks, I guess I need to poke them in all the holes to see where they fit the best, lol. I think the po took them off to paint, they were in a box of parts for 20 plus years.
Old 08-27-2012, 08:48 AM   #6
andrew_k
ogre's photo shows it well. in your original photo, the bottom of the brace bolts to the hole right up from #13. the top goes through the frame, with the attached nut on the outside, then you slide it through and put another nut on.
i know because i had to chisel completely rusted nuts off on mine this weekend! always use stainless!
andrew_k is offline   Reply With Quote
Old 08-27-2012, 04:49 PM   #7
oldcouple
oldcouple's Avatar
Yeah, it was the frame end that had me confused, all the rest go to the bed. To compound it, the po had cut them off and left the ends in the holes so was not sure which hole to use. Once I knew it went in the frame, found the stubs and removed them, all better now! Thanks again to all that helped, on to more little stuff.
