Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-30-2011, 10:42 AM   #1
blazer2007
home made shop tools etc?
Is there a thread on here on home made shop tools,benchs etc on here,if not should start one
blazer2007 is offline   Reply With Quote
Old 09-30-2011, 12:47 PM   #2
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: home made shop tools etc?
id like to see this
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-30-2011, 09:55 PM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
The only tool I can think of right off hand is too simple. Hopefully it will qualify.
I have a big chunk of Styrofoam I lodge over the hood release on my truck so I can climb in safely
without tearing my jeans (and bum )…I’m kind of short and often have to sit right in the
engine compartment to get anything done.
I'm sure there's a zillion other things so I guess I'll be back here often to post...
...and learn new inventions...
Last edited by ETsC10; 09-30-2011 at 09:57 PM. Reason: ... guess I wasn't finished..:)
ETsC10 is offline   Reply With Quote
Old 09-30-2011, 10:19 PM   #4
72lb4x4
I've been known to make jigs and stuff out of 2x4s. They're cheap and once I'm done, I'll break it down and reuse the wood. Lowes has some wood screws with torx heads that get reused.
Last summer I made a rotisserie for a gas tank that needed cleaned out and coated.
72lb4x4 is offline   Reply With Quote
Old 09-30-2011, 10:43 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I made a proportioning valve lock tool out of an set screw because I couldn't find them anymore. I have an old 9" South Bend that comes in hand for things like this.
Old 10-01-2011, 02:11 AM   #6
heeroyue2002
fat old dude
needa have pics of lockdocs smooth cowl jig,
or
Rokcrln cab dolly
Old 10-01-2011, 08:15 AM   #7
truckdude239
truckdude239's Avatar
My make shift door spring tool
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 10-01-2011, 10:32 AM   #8
blazer2007
here are a couple I found that looked interesting
Old 10-01-2011, 04:06 PM   #9
Keith Seymore
Keith Seymore's Avatar
I've got quite a few that my dad made, from before they were commercially available. I'll post 'em up as I can get pictures.
In the meantime, here's my homemade fixture for supporting my pickup bed for transport and paint -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-01-2011, 04:11 PM   #10
Keith Seymore
As an aside, the "trailer" should count as a homemade shop tool, too -
Dad and I built the trailer on the floor of the garage in 1967.
K
1979-1986
1986 - 2019
Old 10-03-2011, 08:02 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I don't have a pic or time to clear the way to get one but my workbench was built from Kitchen cabinets.I used 4 3 w/doors and 1 with drawers.The doors are 2 ft wide and the drawers are 18".The top is made from 4 2X8's on a 1X4 frame(8ft long).I wanted closed storage beneath because my shop tends to be cluttered enough without open storage and the closed doors help keep stuff cleaner.I also used a couple of wall cabinets above it to store other stuff.The back wall is pegboard and the top is spanned by a 1X12(top cabnets are 12") with a 4ft flourescent light.I added 2 8ft flourescents where the original incadescent lights were.I have some open shelving and a folding table for additional space.Plugged a retractable shop light in at the plug for the door opener and mounted it to the support for the GDO.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-15-2011, 08:16 AM   #12
Keith Seymore
As promised, some pictures of homemade tools from my Dad's collection;
I mentioned he was a diemaker at Chevrolet for 26 of his 35 years with GM, so he had access to any kind of machinery or help imaginable. As a result he/they made a lot of tools that were either not available in the marketplace, or just because they could make them for free rather than having to purchase them.
I hit the "mother lode" yesterday - Here are a few I found while I was unpacking:
Homemade tubing bender, for bending 1/2" fuel lines -
This is a good one. It doesn't look like much, but it is made from a turned down cap screw. The small end fits into a connecting rod (piston end) and you swing the rod past the weight on the crank. This is either to (a) ensure you have adequate clearance or (b) use as a fixture to grind the crank weight until clearance is acheived. I've done this at least a couple times.
Homemade tool for pushing the rear axle pinion yoke off the pinion gear shaft (for those stubborn applications) -
Fixture that emulates the bolt pattern of the exhaust side of a Chevy Big Block cylinder head, for use in fabricating header tubes -
Pretty simplistic but still counts: a Drift pin for aligning bolts; I use this one for lining up suspension bolt holes for rear upper and lower control arm attachments -
Homemade tool that keeps the flywheel from turning while torquing attaching bolts/torque convertor bolts/harmonic balancer bolts or installation. The beveled edge is placed in the ring gear teeth and it rotates until stopped by the bellhousing alignment pin or some other feature on the block/trans:
Valve spring compressor for use when the cylinder head is installed on the engine. The cylinder is filled with compressed air and the locks can be removed to repair a seal, or replace/shim the valve spring -
To be honest, I'm not sure what these are for. They were in the tool kit with all the rear end set-up tools. One of them looks like it might be for holding the pinion yoke to keep it from turning:
Homemade bearing/seal installer (fits front wheel "dust cups" too, I believe) -
Homemade slide hammer, for removing the rear axle ring gear/carrier after the caps are removed (for Pontiacs, which are a press fit) -
This is the tool for checking pinion depth when setting up a rear axle. The round portions are held in the carrier saddle and then a depth gage is placed on the flat. The flat is machined to match the rear axle shaft centerline and the depth is measured from there to the rear face of the pinion gear (for Pontiac) -
These are used to keep the pinion yoke from rotating, while torquing or removing the pinion nut and/or crushing the crush sleeve. The fork portion is bolted into the yoke, and then a piece of pipe is inserted over the end -
Not sure what this is, either, but it was in with the rear axle tools and too cool to pass up -
Homemade drift pin/punch, for whatever -
I know there's more up at Mom's house, like a homemade camshaft degree wheel that's about 2 feet in diameter (made before they were commercially available). I'll shoot some pics the next time I'm up there.
K
1979-1986
1986 - 2019
Old 11-16-2011, 12:11 AM   #13
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Keep them coming!!
When I worked for Boeing, I had a whole drawer devoted to my
own fixtures for things I needed to do ... if there was not
the right tool made or it was too much trouble to ask for the
right tool to use just one time (in their opinion).
...so I made my own.
Your Dad did the same. and now more people can benefit.
The wealth of information your dad gave you so you could even
identify these tools is astounding!
Please continue...I'm lovin' this thread!
Old 11-16-2011, 12:59 PM   #14
theastronaut
theastronaut's Avatar
I needed a tubing roller a few years ago when buildig a Targa top for a 1978 Camaro. I didn't want to pay what Eastwood or similar companies were wanting for a roller so I built this one. It's adjustable for different size tubing and has a bottle jack for tension on one of the outside rollers. I wanted the outside to push up instead of the inside wheel pushing down like most rollers are; this way the tubing curls up instead of down towards the ground. If you're making long, broad curves, the tubing will hit the ground if the roller curves the metal downward, mine doesn't have that problem.
Here's my homemade air drier. Used a dorm fridge, a 5 gallon bucket, and 20 feet of copper tubing coiled inside the bucket. It has a water trap on the outlet side and quick release fittings so it can be unhooked and moved easily.
theastronaut is offline   Reply With Quote
Old 11-17-2011, 08:08 PM   #15
PanelDeland
And it doubles as a place to keep your adult beverages at a suitable temp.
Old 11-18-2011, 04:35 PM   #16
Keith Seymore
I have used, and continue to use, most of these; but you are right - I certainly appreciate both the knowledge and the hardware that my dad passed to me.
Here's a few more:
The aforementioned homemade cam degree wheel:
This is a homemade stand, used to hold a burette (like you might see in science class) while cc'ing cylinder heads:
And, these are PVC pipe construction but are slipped over axle shafts during storage, to keep them from getting coated with dirt and fuzz:
1979-1986
1986 - 2019
Old 12-19-2011, 03:11 PM   #17
Keith Seymore
Found a couple more.
This is a spacer, used as a fixture for widening a steel wheel.
The length of the spacer corresponds to the final wheel width.
We used to widen wheels by preserving the front half (thereby keeping the dimensional integrity between the wheel spider and the front face of the rim) and by cutting the back portion off the wheel.
A new back portion, from a different wheel and with an additional 2", would then be fixtured to the front face/spider, using this spacer as a checking fixture.
A small plate was affixed in four locations, allowing for minute adjustments of the donor portion. Once the radial and lateral runout are within spec then the two halves can be welded together.
Here is a finished sample, a 10" Corvette rally with the front spacing preserved and the 2" added to the rear.
1979-1986
1986 - 2019
Old 12-22-2011, 08:55 PM   #18
Gobbles
Gobbles's Avatar
This Bandsaw isn't mine but I used it when cutting my bed wood. I started with 2" thick pieces and cut them in half. With this monster you strap the wood to the guides and push the spinning blade through the wood rather than pushing the wood through the blade. Tons of fun, super loud.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 04-11-2012, 12:34 PM   #19
vegas80step
vegas80step's Avatar
mines a cheap and easy.. but it really helped with my carpet and sound mat install...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 06-06-2012, 09:35 AM   #20
pat 70/71
pat 70/71's Avatar
You sir, are a brave man! I have heavy duty wood working machines and run them every day in my business. Just looking at the pic of that bandsaw makes my butt pucker!!! Scary tool, cheers,Pat
pat 70/71 is offline   Reply With Quote
Old 06-12-2012, 12:06 PM   #21
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Ho many fingers or limbs were lost in the using of this saw? lol!! reminds me of the home made wood splitters with rotating splitter head. search you tube for home made splitters. its funny sh*t.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-02-2012, 12:50 PM   #22
dragginmetal
here, just not logged in
dragginmetal's Avatar
I've been needing a third hand working on some stuff. So i made a stand for my vice.
Name:  5 (640x480).jpg
I made some stakes to go through the lug holes so if i need it a little more solid i can stake it to the ground. Still not 100% if i'm going to use them or fill the base with ready-mix concrete.
Name:  8 (640x480).jpg
dragginmetal is offline   Reply With Quote
Old 08-18-2012, 11:20 PM   #23
ssapach
ssapach's Avatar
I made a frame for helping remove/re-install the box of a pickup truck:
It's pretty simple, although a bit large, but it works like a charm. I ran remove or re-install a box in 5 minutes by myself. I had to do something after I damaged my box a bit when I tried removing it myself with the skidsteer and some chains.
This is another simple tool for helping cut holes in steel with a torch. Just a few large flat washers welded together.
3 different sizes welded together works out nicely. You always have it clamped to the steel so that the hole you want to use is raised up off the steel surface a bit.
Then you put the torch in and simply use it as a circle cutting guide.
It works, although finding the exact hole size you need may take a bit of trial and error, depending on your torch and how well you operate. Naturally, you won't cut a 2" diameter hole if the washer's ID is only 2". You would need slightly larger washers than the hole size you intend to cut.
Of course I can't take credit for the washer jig, I found out about it because of a welder at work. He told me he learned about it years ago from another welder.
ssapach is offline   Reply With Quote
Old 08-19-2012, 10:22 AM   #24
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Great work tools ssapach. The bed jig looks like it would be handy for more than a few chores.
Oh...and Welcome to the Tool Forum!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
Old 08-23-2012, 10:59 PM   #25
midniteblues
midniteblues's Avatar
well mine is allmost like dragginmetal's only its a lil' more portable just a old broken vise that was welded and put back too use on a old engine stand. portable and very handy(kudo's too the kid for puttin this together)pay no mind too the p.w it was only in the pic.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
