08-25-2012, 11:00 PM | #1 |
Any one using the entropy lsx swap rad?
what upper hose did you use? Any help is appreciated!
08-26-2012, 09:33 PM | #2 |
Re: Any one using the entropy lsx swap rad?
I have one, but haven't installed it yet...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
08-27-2012, 10:54 PM | #3 |
Installed but no hose yet...I know Rob we ain't much help......lol....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
08-28-2012, 06:47 AM | #4 |
08-28-2012, 09:59 AM | #5 |
same here.....this is a nice piece....jim
08-28-2012, 10:04 AM | #6 |
A day late and $1 short...
I have this radiator, actually mine is one of the early ones they built so it is a little different than yours. I have some fitment issues, but it is in there. I guess the factory 1500 truck lower hose will work, but I haven't had an opportunity to look at the upper yet. Please share if you get there before the rest of us! lol
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
08-28-2012, 10:09 AM | #7 | |
08-28-2012, 10:23 AM | #8 |
I used the 4 core mounts also, but left them in the stock location. Being an early version, mine is not exactly "factory fit" like the web site says. You must have trimmed the lip off of the core support to move the lower mount back then, right?
08-28-2012, 10:32 AM | #9 |
yep
08-28-2012, 01:24 PM | #10 |
I had them weld a tab on top and bottom so I could use my factory three core mounts this made it a true bolt on.....
08-28-2012, 01:48 PM | #11 |
Any pics?
09-10-2012, 02:31 PM | #12 |
Any one using the factory truck lower hose? I also thought about using these, http://www.summitracing.com/parts/SUM-390024/, for the upper and lower hoses. What do you all think?
09-10-2012, 05:23 PM | #13 |
Used them on the last build they worked fine and look great
09-10-2012, 07:36 PM | #14 |
It seems to be the easy route, but I'm not sure about the look. But, heck it's got a late model fuel injected engine so I guess I need to let go of the idea of the factory look!
09-10-2012, 10:18 PM | #15 |
Would the factory 5.3 hoses work with the radiator ?
Posted via Mobile Device |
09-10-2012, 11:30 PM | #16 |
The lower is a possibility, but the upper is on the opposite side.
10-21-2012, 01:26 PM | #17 |
True Addiction
Looking to purchase this piece... it looks like the trans lines hook up on the driver side? Thanks
RCC |
10-21-2012, 05:17 PM | #18 |
They do. I didn't use them, I used an AFCO cooler mounted on the frame rail.
10-21-2012, 08:26 PM | #19 |
True Addiction
Buck,
Any particular reason why you decided not to use them? Do you think it would not be suffice to cool the trans? Thanks
RCC |
10-21-2012, 08:52 PM | #20 |
I like to use the AFCO rail type coolers and braided lines for simplicity. It's just plain easy.
11-04-2012, 07:59 PM | #21 |
True Addiction
What are the lower mounts for an original 67-68 rad support, I'm guessing 3 row? Also, jtp67-72, did you go with the regular or HD upper cover/mount?
Thanks guys
RCC |
04-23-2013, 01:24 AM | #22 |
Any updates on this subject ? I have this rad , and getting close to installing it . Thanks in advance for the help !
04-23-2013, 02:04 PM | #23 | |
04-23-2013, 02:19 PM | #24 |
I got one from Entropy. I have it installed but have not used it yet. The quality is excellent. I talked to Tony and had him modify a standard 67-72 radiator so the inlet and outlet connections were the right size also, this way the transmission cooler was on the passenger side of the radiator and I could use stock truck hoses.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
04-23-2013, 02:49 PM | #25 | |
