Old 08-26-2012, 08:54 PM   #1
rsmarr1982
rsmarr1982's Avatar
rare truck????
i saw this 70 1/2 ton in my local pull-a-part. after checking it out i discover it was a factory big block. i would think 1/2 ton big blocks would be rare? it also had a bedside toolbox that rusted away and was covered up . i took the grill shell which was in great condition and cost $25 plus i took the trans tunnel i never seen a high hump that was not 4x4 or 4 speed it only cost $4. i looked at the SPID and it said 396 but a sticker under the hood said 402 . is the glove box door most likley from another truck? im getting ready to put a 402 in my 1/2 ton that had a small block it figures motor towers where gone!
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 08-26-2012, 09:57 PM   #2
jocko
jocko's Avatar
Re: rare truck????
396 and 402 are the same - i.e. a .030 over 396 is a 402. Chev switched from 396 to 402 as standard big block in about 70, so it's posisble the SPID still says 396 and you have the stock 402. Not a rare truck, even in a half ton. Glovebox likely original - they sometimes came in black. But who knows - onlyh way to confirm is to see if the VIN on the glovebox matches the VIN on the metal VIN tag. Good deal on the grille.
Old 08-27-2012, 06:39 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: rare truck????
I'd go back and see if it has the big block engine towers. They are a quick $125 or more on ebay!
Scratch that! I see you already looked for them. LOL
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-27-2012, 08:30 AM   #4
Re: rare truck????
Looks like a pretty loaded truck. The last year for 396 was 1969,but for whatever reason the SPIDs still read 396 through '71. That high hump is worth at least $75.
Old 08-27-2012, 09:29 AM   #5
rsmarr1982
rsmarr1982's Avatar
Re: rare truck????
wow $75? i think i might get that posted in the parts for sale section. i figured it might be worth something.
Old 08-27-2012, 09:56 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: rare truck????
You might see if it still has the heat shield on the lower right side firewall/floor pan too. It is held on with two bolts through the pass side floor board. They can be worth 35 or 40 bucks if they are in good shape...
LockDoc
Leon
