Old 08-27-2012, 11:33 AM   #1
82ccshorty
82ccshorty's Avatar
Cummins conversion kits?
I have a 1980 crew cab 4x4 that i want to put a cummins in and i am looking for everything to convert one do they make such a thing?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 08-27-2012, 12:45 PM   #2
SamMargritz00
SamMargritz00's Avatar
Re: Cummins conversion kits?
i know they do but i dont remember the name of the company that did. what version of the cummins are you planning on swapping in?
SamMargritz00 is offline   Reply With Quote
Old 08-27-2012, 12:46 PM   #3
82ccshorty
82ccshorty's Avatar
94 up motor most likely
Old 08-27-2012, 12:57 PM   #4
SamMargritz00
good choice. ill have to ask around here. theres a guy here thats swapped 12 valves into 8 or 9 of his ranch trucks that are all 1980-1986 year range.
but when i looked into it when i wanted to swap a 24V into a 82 crew cab long box i found a company that made all the mounts you need to do the swap. but i dont remember anymore what their name was.
Old 08-27-2012, 01:12 PM   #5
82ccshorty
82ccshorty's Avatar
i know ill need mounts and adaptor plate but what about a crossmember? does it have to be changed also?
Old 08-27-2012, 01:59 PM   #6
Mattman2010
Mattman2010's Avatar
There are companies that make bolt in cross members with the mounts, but I dont remember the names of them off the top of my head. There is one guy that sells mounts that will bolt to the motor that uses all the factory mounts and they sell a cross member that replaces the factory one. But I've noticed a lot of people have firewall clearance issues with that kit.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-27-2012, 02:37 PM   #7
82ccshorty
82ccshorty's Avatar
i'd like to have all bolt in stuff im not a welder. id really hate to have to modify the firewall if i dont need to
Old 08-27-2012, 04:53 PM   #8
Krwright
Fordcummins, autoworld, patc. I used patc mounts they are designed to used factory isolaters. About 1.5 inches between firewall and motor. You'll need a crossmember autoworlds is nice but they are proud of it so be prepared to drop some coin on it. I used the 47 dodge trans because I can get a rebuilt one for less than the adapter for the 400.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
Old 08-27-2012, 05:44 PM   #9
82ccshorty
82ccshorty's Avatar
Can. Get me autoworlds website and patc?
Old 08-27-2012, 07:39 PM   #10
Krwright
Autoworlds is 4btswaps.com. Patc is Transmissioncenter.net
Old 08-27-2012, 07:44 PM   #11
Krwright
Fordcummins.com has some nice adapters. Something like 700$ and 500$ for the custom flywheel for it. Look close at the adapter you choose some offset the trans like 20 degrees I seen a pic of one installed and wasn't pretty.
Old 08-27-2012, 09:54 PM   #12
clinebarger
Auto World....http://www.autoworldmt.com/
DeStroked.....http://www.destroked.com/index.php
clinebarger is offline   Reply With Quote
Old 08-27-2012, 11:20 PM   #13
Metalshapes
Metalshapes's Avatar
I'm not into diesels at all so I don't mind taking the hit on what might be a stupid question so here goes.... what's wrong with the dodge transmission and why not just use it? In my mind all of that low end torque made by the cummins would shell a perfectly good 400 in a very short time. As previously stated Im not even remotely into diesels and on top of that I bleed bowtie so the swap would have never occurred to me.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
Old 08-28-2012, 06:35 AM   #14
odee
look over at the 4bt swaps site lots of info there. Then find tn diesel conversions, scott a member on the site runs it. He has got a bolt in set of mounts for these trucks. There is some minor hammer work on the firewall lip that needed done on mine, but I built all my mounts on a 2wd ton. hope this helps.
odee is offline   Reply With Quote
Old 08-28-2012, 07:19 PM   #15
clinebarger
Nothing at all wrong with using a Dodge TF727, A618, 47RH, 47RE or 48RE.
A well built TH400 will hold up to a stock to lightly modified Cummins 6BT with a high dollar custom built torque converter, But without a overdrive or lock-up converter its not a very good choice.
Old 08-28-2012, 07:35 PM   #16
Pullin81
Pullin81's Avatar
auto worlds site has changed.. i was trying to get ahold of them and there cummins repower site is this now i ordered a accessory kit to run a 1 wire alternator and a harrison ac compressor
http://cumminsdieselrepowers.com/
86 gmc short box..461bbc/th400 12.95@106mph
85 gmc crew cab 4x4 8"lift cummins conversion
Pullin81 is offline   Reply With Quote
Old 08-29-2012, 12:49 PM   #17
82ccshorty
82ccshorty's Avatar
would i need a adaptor to run a allison 1000 on the cummins?
Old 08-29-2012, 01:31 PM   #18
Mattman2010
I think you just need a sae bellhousing adapter for the cummins. They had them on the bigger trucks that had the cummins in them.
Build Thread
Build Thread
Thread
Old 08-29-2012, 07:26 PM   #19
clinebarger
The Allison 1000 used behind Duramax or 8.1 BBC have a "standard" Chevy bell housing bolt pattern.
Destroked has adapters for this http://www.destroked.com/prod_adapters.php
The Allison 1000 used in other application have a #3 SAE bell housing bolt pattern.
Bolting it up is the easy part, Buying a controller to make it shift is EXPENSIVE!
Heres one from Destroked http://www.destroked.com/prod_electronics.php
Old 08-29-2012, 07:34 PM   #20
82ccshorty
82ccshorty's Avatar
Wow. That's pricey. What auto Trans would you guys recommend?
Old 08-29-2012, 07:48 PM   #21
Dunenutt
Newbee
Dunenutt's Avatar
The only transmission That I can get to stay together in my dually is this..
http://www.atsdiesel.com/ats2/produc...ge/use/3092218
I beat on it hard, tow stupid weights, and generally drive it like a ricer. My motor runs pretty good too.
Dunenutt is offline   Reply With Quote
Old 08-29-2012, 07:59 PM   #22
clinebarger
47RE or 48RE, The TCM & harness can be had out of a 96-02 Dodge fairly cheap ($300 usually).
Ive done a few of these swaps, Do yourself a favor & buy a entire Dodge diesel truck thats been wreaked, Fab the Dodge motor mounts in, You get the engine, engine wiring, trans, trans wiring, trans cooler lines, radiator, CAC, down pipe etc.etc....All those little thing will add up fast if bought new/separate.
Old 08-29-2012, 08:03 PM   #23
82ccshorty
82ccshorty's Avatar
What did you pay of you don't mind me asking?
