#301 |
Re: Rustbuket 67 build "Georgia"
Ive seen them done without bracing and had some serious power underhood and never had any problems mike.
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
#302 | |||||||
I am a boob !! I was having shielding gas flow issue the other day not contamination. There was some buildup in my nozzle on one side so I was not getting sufficient flow when welding from right to left. Why didn't I check that ?? Duh!
![]() Quote:
![]() Quote:
![]() Mee too, Looks cool though!!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#303 | |
is it done yet? |
#304 |
Okay where was I ?? Did some more welding on the exhaust cut outs once I flipped the frame. The problem I was having welding was that my nozzle was partially clogged so once I let go of the trigger my last weld would pit on the top so I ground out the pitted top welds and went back over them. lots more pics/progress to come!
#305 |
Next I had to grind off my partially pitted top welds and finish the frame repair. Still need to smooth the out side and box later. Once it is a rolling chassis it will be going to Merle's frame and alignment to verify the frame is straight then I will box and add a big notch.
#306 |
Borrowed the super duper suspect press to remove my trailing arm bushings. I need to order some energy susp bushings and have yet to take the trailing arms and front control arms to the blasters. busy busy!!
#307 |
I have been busy at school and this major home improvement... Cost me a few Porterbuit Drop Members... But hey no more panicking when the tornados come. It is in the garage floor but flush, well maybe 1/2 above the floor and you can park over and actually on it.
#308 |
Man of Mini-Talents
Apparently I'm the only Oklahoman on this forum that doesn't have crazy metal working skills. Really neat build thread, Dan!
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#309 |
Back to the truck I found out that once upon a time my truck had busted a lower control arm U bolt and it messed up the shaft alignment pin rivet. uggh Georgia led a hard life. Last pic is the the other side of what it should look like sooo.....
#310 |
I had one of the guys at work spin me up a new one.
#311 |
I bought some new control arm U bolts but the only ones available are the 73+ version (Napa pn 650-4065) which are 9/16 vs the old 7/16? so I had to drill out the holes. Snapped one drill bit then bought another. What else could go wrong with this truck?!
#312 |
So I mocked it all back up with a new Moog shaft and went to welding it all back in.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 09-23-2012 at 12:36 AM. Reason: spelling |
#313 |
Here it is welded back in. Next I have to finish a few other things on the frame and do some painting..
#314 | |
#315 |
Master Procrastinator
Looks good, your build is coming along nicely
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#316 |
Nice work and nice tornado shelter. Isn't it crazy how all the little things you think will be easy end up eating up huge amounts of time?
#317 | ||
![]() Join Date: Oct 2011
![]() . Looking good Dan!! . .
Wade ![]() , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
#318 |
![]() Join Date: Oct 2010
Nice work Dan ! as usual.
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
#319 |
67cheby
![]() Join Date: Sep 2008
Impressive !
Posted via Mobile Device |
#320 |
![]() Join Date: Mar 2011
Nice repairs...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#321 | |
#322 |
Looking good! I had a broken one of those pins also but I was lazy and just stuck a bolt in there. Does not look nearly as nice as yours! Something that I discovered was that if you cut the U bolts with a hack saw shorter (as my biggest pet peeve of all time is threads sticking out of a nut, weird I know) and then unscrew the nut to just a little below flush you can grind with a flap disc (I use 120 grit) the hack saw marks off and then magically you have a shorter bolt. Then you just unscrew the nut off the rest of the way and I very lightly sand with the disc the radius of the bolt and yuo would never know it from a factory shorter one. Obviously you have to paint it then but I do not trust that gold zinc coating anyways. Just a suggestion, do what you want though! I like how you welded around these stands also. Good idea and I wish I had done that.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#323 |
Where's the pictures? I know you've done something to this truck in the last month.
#324 | |||||
Thanks Wade. Summer is over... ![]() Thanks John, appreciate it! Thanks Mike, Should have just bought a DM instead of fooling with fixing all these old suspension parts. ![]() Thanks Jim! Quote:
![]() Quote:
#325 |
I stripped my trailing arms with a wire wheel on a 4 1/2 " grinder. still need to spot blast a few spots that I could not get to.
My daughter wants to help me so here she is: ngmjdhuyejuuihkhblhkghkdjhuhkkhhkhjhk. ![]() ![]() ![]() ![]() ![]() ![]() She wanted the purple one, the monkey and the flag
