Headers ??
Hello
I have a 87 R20 350 tbi and my stock manifolds are being a pita. So I was thinking about getting some headers. And after searching and reading for hours now. I'd thought I'd just ask. Long tube, mid length, or shorty's? Would there be any real difference in a stock 350 tbi as a daily driver? Thanks |
Re: Headers ??
For convenience of running pipes and in my opinion a better look and performance, long tubes. I have been running Hedman Elites for the last few set due to 3/8 flange, the ball type collector, quality and accurate fit. They do cost a little more but the fit better than any I have ever installed. I use the ceramic ones and I have been very pleased.
Badass
Re: Headers ??
if you plan on lowering your truck more than 5 inchs up front you want to rethink long tubes. but besides that they are great. also dont cheap out and get painted ones they will burn off that paint and rust so fast. get ceramic coated ones. or jet-hot coated like i have.
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: Headers ??
No lowering planed, and I was thinking about stainless. I guess my main concerns are fitting them and O2 sensor. The mid's I found have the o2 sensor bung, but the long tubes don't.
Re: Headers ??
Long tubes will give you better sound and low end torque. As for the O2s, you can get the weld in bungs for next to nothin.
1977 Scottsdale shortbed stepside 4x4.
350, 4spd, NP205. 10 bolt front, 12 bolt rear 4"(?) lift and 35s. |
Re: Headers ??
If you spend the money on long tube Doug's or Doug thorley they don't hang lower than the frame. Then you have nice ceramic covered headers that don't rub
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Headers ??
You can get collectors with the O2 bung in them for about $25 from Summt if needed.
I've never run Doug's but they have been around for 40 years so they must have something going for them. |
Re: Headers ??
They will also weld in bungs for you or anything custom
Getting Old; Going Broke
Re: Headers ??
If you move the O2 sensor that far back (to the bungs) make sure to switch to a preheated sensor and save yourself some headaches.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
BAD BOW-Silverado XST
Re: Headers ??
Re: Headers ??
The mid's I found look just like those Chevelle one's. So they fit well?
Re: Headers ??
I just bought and installed some headers from O'rielly's for my 87' R10, since they never seem to have anything that fits a R10 but had some for a 86 C10 in stock I took those... Cheap ones $150 I also have a TBI 350 and there is a O2 on the drivers side... No place had a bung so we cut one of a stock Harley pipe and welded it in the drivers side header...
![]() Stock Harley pipes ![]() ![]() ![]() ![]() Done... ![]() |
Re: Headers ??
Opps forgot something I have power steering and AC... Had to cut a piece off the bracket at the front bolt by the number 1 cyl. Hope this helps.
GM Addicted
Re: Headers ??
How low is your truck?? Measurment from fender to level ground would help. Looking for headers but dont have much clearance with a 26.5 tall tire and 5 inch drop in the front. Dont really like the chevelle headers due to plug wire routing was a PITA on the chevelle i just got done building.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#15 |
Re: Headers ??
Stock ride height for 3/4 ton 2wd and 30" tires. No plans to lower it, so I don't think ground clearance is going to be a problem. But thanks plug wire routing is something to consider.
#16 |
At the body shop.
Re: Headers ??
Caddy dougs d310c. Mine tuck nice.
http://m.summitracing.com/parts/dou-d310 Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#17 |
GM Addicted
Re: Headers ??
Got some pictures KQQL IT??
#18 |
At the body shop.
Re: Headers ??
![]() Posted via Mobile Device
#19 | |
Re: Headers ??
#20 |
GM Addicted
Re: Headers ??
Nice, might have to snag up a pair of these headers very soon
#21 |
At the body shop.
Re: Headers ??
I started with a double hump...
#22 |
Re: Headers ??
#23 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
Re: Headers ??
Long Tube!!! I have shorties and they are always loosing the bolts!!!
